Those should sound good. Had them in my old Formula minus the tweeter and was happy with them.
Project: PBR-Built Z/28
- Greenville, MI
- Die Maker
I've had some Type R's sitting in my closet for about 7 years now...never got around to installing them
One day I'll find something to put them in!
I already have these in the back of the car and even with only 2 speakers they are enough to be heard over my duals. This should help them not have to work as hard though, definitely a good set of speakers. 4 of them should be louder than is desirable to the ears
Lurker
- March 13th, 2010
- 3476
- TJ
- 1995 Chevy Camaro Z28
- Clinton Twp Michigan
- Powerline Tree Trimmer.
Are you using the stock amp?Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Pioneer head unit-Joel
Not sure, i hade the basic cassette head unit in my car originally. Other than that internal amp my car did not have one.-Joel
Those had a Bose system which had small amps at each speaker, vs. the Monsoon's one amp that powered them all.Originally posted by nascarnate326 View PostDid LT1 cars have an amp?
Door speaker w/ amp, for example:Gone but not forgotten: 1986 Chevrolet Camaro IROC-Z
Lurker
- March 13th, 2010
- 3476
- TJ
Yeah I have Bose in mine and running a Pioneer Head unit. Which isn't that great because the head unit puts out higher wattage then the amps just step it up even higher.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Made it over to the house today and made some progress... nothing really worth taking pictures of though. Most of what i did was cutting and grinding to get my alternator to fit into its new home. Not an easy location to maneuver cutting tools. I will say this job is more involved than I was led to believe. Going to be a snug fit. Also got a new aluminum driveshaft ready to swap in (hoping to fix a vibration). Next time I am there I hope to get everything bolted into place so i can measure for an accessory belt and start with the plumbing for the power steering.-Joel
Thats what i thought too, expected a 100% bolt-in. Apparently for some people it is, it was no where close to fitting in my car. it should be good to go now i cut the (unecessarily long) bolt down for the sway bar bracket as well as the tab for the kmember on the frame rail.-Joel
