Finally got started on it today, but I was not able to grab the pickle forks from my buddy this week at work, as he didn't get them into his car until Friday, which is when we stayed home due to the impending snow. I tried for probably an hour with a crowbar, but to no avail - simply can't get around the ball joint stud, so not enough of an area to grab/pry like a pickle for would.
The good news is, the ball joint nut and the two upper control arm nuts came loose with any kind of extra hassle - that's always a plus! So those are loose, but until I get the pickle fork, there'll be no splitting the control arms from the spindle.
Also, those upper control arm bolts (the ones that are attached to the frame) are going to pose an issue it looks like...does not look like there will be room to get the control arm off without running into the headers. Dammit.
