Cut and labeled all my extension wires for the factory cluster harness to the HDX control box, then connected them all up in the dash. Everything seems to work (I can't test the speedo or the coolant temp sensor at the moment, nor can I check the high beam lights, since I have the headlight knob disconnected. But the oil pressure, fuel level and voltage gauges all work. However, the tach, does not. I'm not sure why, but the factory tach lead to the cluster doesn't seem to be the same as what comes out of the distributor. I've inquired over on NastyZ28 as to why this is, but that should not be difficult at all to tap into that line and run it into the car (I found a grommet RIGHT there, which apparently I missed when I decided to run the wires all in through the speedo cable hole. Oh well!) if there isn't one already.
Anyway, the limited time I spent using the cluster was pretty outstanding. The control buttons are metal and capacitive touch, which is really modern and up to date, and the screens look great, as does the lighting. Just can't wait until all the gauges work! I think I may tap into the headlight feed from the light knob (not the dimmer output at the cluster) to connect to the "dimmer" on the HDX box. That way I don't have 3.5 x 10^40 lumens blasting me right in the eyes at night.
Everything (well, mostly) hooked up to the HDX box:
Screens on (backlighting off):
