Waiting on my IR angle air drill to arrive (Monday), but I wanted to at least get everything I could get done up until the point where I need the drill. Got the bar mounted to the axle, and unbolted the fuel/brake line clips that I need to (per the instructions). I'm limited on the driver side U-bolt, due to the brake line bracket that is welded to the axle, so I will match it when I do the final tighten on the axle mounts after everything is done.
I went right into installing and forgot to take comparison shots off the car, whoops! But comparing the stock bar to the Hotchkis bar on the car does show the difference in attachment schemes. The ends of the stock bar mount to the axle at the leaf springs, with those long "mid links" going up to the roof of the axle hump. The Hotchkis bar mounts to the axle (near where those "mid links" were on the stock bar) and the end links mount to the "frame rails". A much more rigid setup and should be far more effective. The bar is also much larger at 7/8" vs the stock 0.594" (~15mm).
Just waiting on the end links to be installed:
