Back in an F-body, time for a turbo!
  • No exhaust/Open headers? That would be loud enough...
    Dang. Didn't realize Joelius beat me to it
    99 Trans am
    - SLP Air Take (LID)
    - Ported and Polished Throttle Body
    - LS6 Intake Manifold
    - 1 3/4 Long Tube Headers
    - 3" Y-Pipe
    - 3" Magnaflow Catback
    - Lower Control Arms
    Soon
    - Heads/Cam
    - 3600 or 4000 Stall
    - 3.73 Gears
    • Looking for quality loud. Not crap lol
      2002 Z28 Camaro A4
      1993 Z28 Camaro M6- SOLD
      1999 Z28 Camaro M6- SOLD
      2008 Ford Fusion SE - DD
      • speed engineering stainless LT's and a Texas Speed true duals.
        • A buddy of mine (though he wasn't the brightest) Just ran straight pipes back and I think muffler man or whoever did it charged like 100 bucks. Actually didn't sound bad and was really loud.
          99 Trans am
          - 3" Y-Pipe
          Soon
          - Heads/Cam
          - 3.73 Gears
            Throw a couple cherry bombs on it then. Jk
            • http://www.speedengineeringlsx.com/s...ersion-25-1021
              i have these and they fit awesome. they are cheap and you could pretty easily sell them in a couple years to make some of you money back. pair them with that $275 true duels setup that HSP has on here and you'd have an awesome sounding car for pretty cheap.
              • dont you still have the 2otl? Just weld the ypipe to manifold to stop leak and then put on the 2otl for the time being
                • Originally posted by white97z28 View Post
                  That 2otl is pretty quiet. A guy is "suppose" to be meeting me from ohio next month as his wife just had a baby. He is putting his 97ss back to oem.
                  2002 Z28 Camaro A4
                  • Originally posted by formula218 View Post
                    Is the extra $40 worth it for 1 7/8s over the 1 3/4? Also what are you using for gaskets? [MENTION=4062]formula218[/MENTION]
                    2002 Z28 Camaro A4
                      Is the extra $40 worth it for 1 7/8s over the 1 3/4? Also what are you using for gaskets? @formula218
                      i'm not sure, id say go big or go home, it's only $40. if you don't car about the couple HP then the 1 3/4 are fine I'm sure.
                      no gaskets, the were all slip fit with clamps included.
                        YES. If anything you won't wonder "what if"
                        Wish I had did the 1 7/8. I doubt it would be any faster but still wish I would have did it.
                        • I wouldnt do 1 7/8 unless i was making that level of power or planning to. Always better to match a combination and you also have more room to change plugs etc.
                          Also the 2OTL should not be quiet. Mine was pretty loud. Make sure it doesnt have the "cone of silence" if so you should be able to remove it.
                            For the gaskets I was referring to the header ones. Did you just use the ones they come with or pay the extra for the "gm" ones.
                            It's might have had the cone I'm not sure joel. It was welded to the muffler so I didn't want to bother cutting it and re welding it.
                            2002 Z28 Camaro A4
                            • i ordered two new OEM gaskets for mine.
                              • If you're looking to stay cheap and just get "some" noise for now. Why not just replace the last muffler with something, Magnaflow, borla. Cheap-ish and will make more noises than it does now.
                                1997 Trans Am
                                T56 swap. LS1 Cosmetics
