one thing i mentioned to you in PM your block may not be roller quipeed so that needs to be taken into account.
John's 1991 and 1992 Camaro Project's
- November 8th, 2009
- 3000
- Tyler Porter
- 85 Z28, 91 Trans am
- Clinton Township Michigan
- student
00 Tahoe Z71........Stock
- Greenville, MI
- Die Maker
Work hard, save your pennies. Cam swap is your best bang for the buck. Stock 305 with LT1 cam and a chip will put you close to the TPI output, had a member here request a chip for the same setup and he ran a 15.2 if I remember right.
- 3000
- Tyler Porter
- student
also ask around i got my last lt1 cam from nascar nate as he just did an lt4 hotcam swap in his old car.91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
So after doing some more research I have formed 2 questions.
1. The TBI unit in my car is a SD based system. On a thread I found from TGO one reply said that I do not need a 350 ESC module because my car is SD. Can anyone confirm this?
2. I found a used LT1 can for sale in my area for $50. Would this even be a noticeable upgrade? It is only a tiny bit larger than the stock l98 cam. Also would I need to modify my heads to accept the higher lift like I would if I used a zz4 cam? This by far is not my specialty area so any help is appreciated.
Thank you everyone, hope you all had a merry Christmas!1991 Camaro RS: "Tiny Turbo Mullet"
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
Sounds like your staying with the throttle body and EFI. Smart move! going to Carb is moving backwards. EFI is state of the art and can easily give you what you want.sigpic
Disagree with both of you. Carb blows away TBI all day long. You can get the same reliability and mpg out of a carb without the crappy technology of TBI and the chip burning.
Sent from my iPhone 6+ using Tapatalksigpic
Neither does a 350 or 305 TBI. I've had both in perfectly stock form and modified. TBI is junk and your waisting your time with it. But hey if you want. Swirl port heads, a terrible throttle bottle injection fuel system and a ugly engine bay its your car! A stock 350 with the right carb dialed in correctly with a screw driver not a expensive chip which are never spot on will perform just as reliable, just as efficient as tbi and cheaper easier to maintain and tune. Unless you already have a running driving 350 tbi 350 computer and harness. your waiting your timeOriginally posted by C2YT View PostDarren I haven't heard of a carb that can get 25+ mpg on the highway.
- 3000
- Tyler Porter
- student
my 85 used to.Originally posted by C2YT View PostDarren I haven't heard of a carb that can get 25+ mpg on the highway.
