View Post
John's 1991 and 1992 Camaro Project's
A carb converted LT would use a traditional distributor
I have a TPI 350 take out if you need it._JASON
http://www.hardingmotorsportsllc.com
2015 Chevrolet Corvette Z06/Z07 (my toy) http://www.mifbody.com/vbulletin/sho...323#post898323
2015 GMC Sierra 2500HD Denali Diesel (daily driver/tow vehicle)
2014 BMW 435i (wife's)
1989 Chevrolet Camaro IROC-Z http://www.mifbody.com/vbulletin/sho...t-Rod-Magazine
1991 Chevrolet Camaro Z28 1LE project http://www.mifbody.com/vbulletin/sho...28-1LE-project
1993 Chevrolet Camaro Z28 Indy Pace Car
2006 Ferrari F430 FOR SALE: http://www.mifbody.com/vbulletin/sho...6-Ferrari-F430
1993 Chevrolet Camaro Z28 Indy Pace Car FOR SALE: http://www.mifbody.com/vbulletin/sho...-Indy-Pace-Car
1999 Pontiac Trans Am 30th Anniversary FOR SALE
Jeremy,
That sounds like a pretty interesting build, could you send me a message of what you are thinking price wise?
Jason,
Is the 350 tpi from your 1LE project? Also would the wiring harness and computer be included? If you could send me a message with a price that would be great.
Just want to say thanks to everyone for putting in their thoughts. You all have a lot more experience than me so I weigh your opinions very highly.
John1991 Camaro RS: "Tiny Turbo Mullet"
Yes, the 350 TPI is from the 1LE. I gutted the harness to scavenge some pieces I need from it, so it's no longer around. I have the ECM if you need it. PM me an offer. I'm not sure what it's worth.Originally posted by C2YT View PostJeremy,
Jason,
John_JASON
Post Whore
- November 8th, 2009
- 3000
- Tyler Porter
- 85 Z28, 91 Trans am
- Clinton Township Michigan
- student
ooooooooooh thirdgens...... darren does get 7mpg but his driving habits are how shall you say quite spirited. id figure out what you want the car to do, lt1s arent terrible, joels car is impressive to say the least for the little work hes done motor wise. a carb isnt all that bad of a plan either. just food for thought though, 4.8s and 5.3s are getting cheaper all the time, theres a junkyard near me that has any motor for 250 bucks, if you can check compression and run a few tests on it there it might be a viable option....but theres alot of hidden expense even with dropping into a relatively stock motor.
i say keep the 305 or toss that 350 in for now, keep your costs low as you can get lots of used but still good parts all over inline, facebook, ebay, amazon, etc etc. if you wanted to keep the turbo idea, your 305 could be a donor for that as well theres a few builds on tgo of turbo 305 cars that look like quite a bit of fun.
yes to ls1 brakes, definitely swap in the posi rear, i like red interiors and black, gray to me is kinda bland and tan is classy but thats only my opinion. apparantly since snatching a set of seats your choice is definitely the gray. other than that id work into whatever your ultimate goal it, a gen 1sbc will do you fine till you can afford what youd truly like. ive learned multiple times that having your car torn apart for a long time makes you lose interest and makes you go a bit nutty and start going wild on it. KISS: keep it simple stupid, is a pretty good motto to go by.91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
00 Tahoe Z71........Stock
Id hit that 305 with a hefty shot of nitrous. 305s are tough chances are it wont hurt it one bit and if it does oh well!-Joel
Hey everyone,
Hopefully going to look at a 350 tpi after Christmas. If I go this route I can keep my costs low and save money for down the road. It will get me what I am looking for without breaking the bank. I think it would be cheaper to convert the engine to carb too. What do you guys think?1991 Camaro RS: "Tiny Turbo Mullet"
Post Whore
- 3000
- Tyler Porter
- student
use your tbi91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
Post Whore
- 3000
- Tyler Porter
- student
you could be okay retuning yours, and easers and cheaper than buying a bunch of stuff for carb, i mean carbs fairly easy too. primitize how? lots of potential sure others have more but many underestimate it. great for torque and reliability not really for performance, just an option if you want to keep things super cheap91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
Post Whore
- 3000
- Tyler Porter
- student
well in that case go carb, just suggested tbi because you wouldnt have to have many more expenses91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
Well there is work regarless of what direction you go..
if the car is currently TBI.. for the sake of simpleness.. I would stay TBI.. yea might have to get a new ecm chip.. but if you go over to thirdgen.org and post that you need one.. you can probably get on sent pretty cheap.. but really.. you wouldn't need to do a crazy ton to the car.. unless you start modifying stuff for performance.. and even then.. you are gonna run into the same problems with TPI and Carb too..
Swapping to a carb'd setup isn't just a direct swap either.. for 1 thing.. your fuel system now will now have too much pressure for a carb'd setup.. so you will either need to swap out the fuel pump or install a fuel pressure regulator.. you also would need to go through your wiring harness in the engine bay (unless you want a bunch of useless wires hanging out).. something you should also note here is that carbs need a little more maintenance than a fuel injected setup.. they can gunk up over winter if not winterized.. will need to be rebuilt eventually.. and has a harder time starting in the cold.. some of these might not be an issue for you.. but figured I would mention it.
Swapping to TPI would be the hardest to do.. but not impossible.. you need to not only get all the parts for TPI, you will need to make sure you get the ECM and wiring harness too.. which requires you to swap it out that runs through your passenger fender into the cabin area of the car to under the dash.. not crazy hard.. but the most effort.. just need to make sure all the sensors are hooked up and so on.. I'm not sure on the fuel pump.. what pressure ratings it require and so on.. also not sure if the fuel lines are ran on the proper side or not to hookup to the fuel rails..
if it were me.. I would just stick to the TBI for now.. and then later swap over to a better platform all together.. because for a stock or mild performance application.. the TPI and TBI setups are both capable of handling it."Project Shadowfax" <- Clicky Clicky
