dun ****ed up a-aron
John's 1991 and 1992 Camaro Project's
Post Whore
- November 8th, 2009
- 3000
- Tyler Porter
- 85 Z28, 91 Trans am
- Clinton Township Michigan
- student
00 Tahoe Z71........Stock
Post Slut
- December 9th, 2011
- 5919
- Michael H
- Greenville, MI
- Die Maker
Ok so luckily I'm un-grounded starting tomorrow
Ran into a little snag though. Looking over my parts list I forgot about the throttle cable differences. Any one happen to have an extra one laying around? The TBI one is to short.
Maybe there is a way to modify it?1991 Camaro RS: "Tiny Turbo Mullet"
best way is to get this:
http://www.summitracing.com/parts/lo...0ls1/overview/'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
Post Slut
- 5919
- Michael H
- Greenville, MI
- Die Maker
Yep, Lokar or NOS
Brandon in Paw Paw might have one, send him an email
http://grandrapids.craigslist.org/pts/4902498169.html
You will need the 89-92 cable
Lokar makes good stuff. I had thier throttle cable on my LT1. Never had a problem and looked fantastic.sigpic
Little update...
You wouldn't think that taking out 7 bell housing bolts would be difficult, but man those suckers are on tight. Disconnected the exhaust at the y-pipe and everything else is undone. All that is left is the motor mounts and the need for 30+ degrees!1991 Camaro RS: "Tiny Turbo Mullet"
Another update, promise I will have pictures soon. Nothing has been "worth it" so far.
A. Pulling engine in the morning. Just need to push it outside and hook it up to the cherry picker.
B. Went outside to check the 91' and saw my MINT dashpad is now cracked. Damn Michigan weather. It's a very fine crack, would some black apoxy be sufficient to stop the spread?1991 Camaro RS: "Tiny Turbo Mullet"
Look at that beautiful L03! A modern marvel of Gen. 1 SBC engineering. Thin wall castings, high nickel walls, swirl port heads, roller cam, EFI, electronic ignition...pure motoring bliss!
I think you should paint that up and put it in the corner, on display for all to admire.
Post Whore
- 3000
- Tyler Porter
- student
i want the bottom end!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!Originally posted by C2YT View PostI'm toying with the idea of turning it into a coffee table for my room lol. Take out the pistons, weld them to the block, buy some plexiglass. Sounds like a good idea.91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
#streetbeast #torquemonsterOriginally posted by DynoDave View PostLook at that beautiful L03! A modern marvel of Gen. 1 SBC engineering. Thin wall castings, high nickel walls, swirl port heads, roller cam, EFI, electronic ignition...pure motoring bliss!
