If it were me I would install a 4th gen fuel tank. I have one out of a 1999 Trans Am.
Brians 91 Z28 projects thread
no prob!
Brian, I have a list of swap part numbers if you go that route.Last edited by Gregs_gsxr; January 17th, 2014, 03:58 PM.'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
Obsessed- June 6th, 2012
- 505
- Brian
- 1991 Camaro RS/1991 Camaro Z28
- Wixom Michigan
- Truck Driver
Thanks guys! I will have to look up the guy on here that has one. As I said before I will more than likely carb it to start with. I think for the carb set up all I will do is upgrade the pump. Later when I run the injection I will run a fourth gen tank if I can find one. The house we're in in does not have much storage space so I have no room for an extra tank at the moment.sigpic
- 505
- Brian
- Wixom Michigan
- Truck Driver
- Lowell, MI
- Meat Processor
Originally posted by deeznuts94 View PostSweet! How soon are you planning on firing it?
I forgot to finish the pin to pin instructions and send Greg the info packet
- 505
- Brian
- Wixom Michigan
- Truck Driver
well its cold outside, and its my busy season at work, so hopefully in the next month probably 2 months. Truly its right there, finish wiring and add gas.'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
- 505
- Brian
- Wixom Michigan
- Truck Driver
Going to carb a LS? Or your motor you have now? I wouldn't carb a ls it's so easy to drop a complete package in and roll...
That said I think you should do a carbd sbc build but I am biased.Last edited by Darren; January 25th, 2014, 09:22 AM.sigpic
- 505
- Brian
- Wixom Michigan
- Truck Driver
Yep. I just dont want to swap the harness and play with all of the computer stuff until I paint the car. I know a few guys running carbs on their LS swaps. They run really good. All I would need is an MSD 6LS to fire the coil packs.
Not sure if I did those links right but these are a couple of guys that I have talked to about it. Darren if you know anyone that has anything I would be interested in checking it out. Not opposed to the old school stuff, but it has to be nice and it has to make over 300 horsepower.sigpic
- 505
- Brian
- Wixom Michigan
- Truck Driver
Obviously I wouldnt want something this fast to start with, but these guys are saying with some motor mounts, headers,the msd box and some, other little odds and ends I could have it running and driving.sigpic
here is a start, might be also able to talk him down a bit too
http://detroit.craigslist.org/okl/pts/4294695480.html
edit: another good buy, can't go wrong with a 5.3, run it NA carb or boost it later
http://detroit.craigslist.org/mcb/pts/4302019404.html
edit 2.0: complete, now we just find you a 4l60e trans.
http://detroit.craigslist.org/okl/pts/4292395344.htmlLast edited by Gregs_gsxr; January 25th, 2014, 09:29 AM.'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
