Do you think they do repair on leather stuff? I have a very small (albeit very visible) tear on the leather on my driver's side door panel. Pretty much the only blemish on my entire interior.
Brians 91 Z28 projects thread
Post Whore
- February 19th, 2010
- 3991
- Peter Schultz
- 1996 Z28
- Livonia/Plymouth
Obsessed- June 6th, 2012
- 505
- Brian
- 1991 Camaro RS/1991 Camaro Z28
- Wixom Michigan
- Truck Driver
Give them a call 248-474-7520. I'm sure that if they don't do those kinds of repairs they can recommend someone that can.Originally posted by alone_and_insane View PostDo you think they do repair on leather stuff? I have a very small (albeit very visible) tear on the leather on my driver's side door panel. Pretty much the only blemish on my entire interior.sigpic
Post Whore
- November 8th, 2009
- 3000
- Tyler Porter
- 85 Z28, 91 Trans am
- Clinton Township Michigan
- student
how much did it cost out of curiosity if your comfortable with giving that out. im wondering how much other shops are charging other than the one i work for.91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
00 Tahoe Z71........Stock
- 505
- Brian
- Wixom Michigan
- Truck Driver
Tyler, it was $300 for the front buckets. All they did was recover them, and replace some foam on the drivers side seat. Had I known that you worked for an upholstery shop at the time I would have got in touch with you for an estimate first.sigpic
Post Whore
- 3000
- Tyler Porter
- student
yep i work at one, and the owners brother owns one at well. very good quality work.91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
- 505
- Brian
- Wixom Michigan
- Truck Driver
Post Whore
- 3000
- Tyler Porter
- student
yea i think we would be right around there, hard to tell not knowing their procedures we usually do a top foam layer as well as fix the foam needing repair, and all out material is brand new as well as the thread patterns and seat patterns are all fixed verse stock patterns91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
- 505
- Brian
- Wixom Michigan
- Truck Driver
Right. See if you can get me a quote for the rear seats. I plan on doing them with my Dad, but we have a lot of other stuff going on with the car too. It might be worth it to me to pay to have them done. Its a split back rear seat.sigpic
Post Whore
- 3000
- Tyler Porter
- student
id say go to the one shop that did your fronts otherwise they may look wrong as the materials might not be the same. that happened once we had a customer come in a dn he wanted only one seat done so we did it and it made the other stick out so he took it to a different shop to get the other recovered and ours still looked better so he came in a had us redo the other one again.91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
- 505
- Brian
- Wixom Michigan
- Truck Driver
Yeah, that make sense. Hopefully the ground is frozen enough that I can get the car out of storage today. Last time I was out there it was so muddy that I didn't even try to get it out.sigpic
- 505
- Brian
- Wixom Michigan
- Truck Driver
- 505
- Brian
- Wixom Michigan
- Truck Driver
irocs.jpgirocs2.jpg Finally got the car out of the barn last weekend. I put the Iroc's on and that was about it. I picked up the last of the stuff I need today, minus the trans fluid. Tomorrow we should be working on the t-top seals and maybe starting on the rest of the interior. Finally some nice weather to work in!sigpic
- 505
- Brian
- Wixom Michigan
- Truck Driver
So, I figured out why my tops were leaking so bad. The rubber and trim pieces on the glass were on the wrong side, and there was no glue used whatsoever when the previous owner or shop installed the last set of seals. When I figured out how bad they leaked I inspected the seals and they looked brand new, no cracking at all. Needless to say I was pretty shocked to find out there was no adhesive at all, anywhere. Some people...
We did make some progress today in cleaning up surface rust and prepping everything for the new seals. We used Chassis Black paint on the tbar and the panels and the tbar and around where the seals go. Here are some pictures.tops1.jpgtops2.jpgtops3.jpgtops4.jpgtops5.jpgtops6.jpgtops7.jpgtops8.jpgtops9.jpg
