Huron Speed A/C Turbo Kit - Another Reason to Tear Into It
Plan on using your 3600 Yank? Sticking with the 10 bolt w/ 3.73's also?
Mike, I'm going to stick with the Yank stall for now but was thinking about swapping the rear for with the ol' 3.42 I have sitting in the corner. I think it only has 14k miles on it or so, right Brent?
I had he 3.42 in the car at one point but never had it under power. Then found a complete 3.73 which work out rather well with the old configuration.
....to be exact
Brent you ........ I worked on the water bottle today and what a pita that is! I scuffed it and tried to straighten the surfaces out a little but that plastic material gets "fuzzies" when you sand it. I used many coats of filler primer. Needless to say it is not going black!
I found headlamp housings that accept a HID bulb. Now they should match my fogs.
Pssssch.....rookies
....keep working on it, it'll get better.
Yeah it does. I sure hope nobody is looking forward to my build lol. Mine is just going to hopefully work. I don't have the time, patience, or cash for A build of this sort
