Huron Speed A/C Turbo Kit - Another Reason to Tear Into It
  • #31
    Looking real good
    • #32
      Very nice progress!
      • #33
        Originally posted by birdie2000 View Post
        This is moving far quicker than any winter project should.
        Looking good!
        quoted for truth
        Originally posted by JasonH
        • #34
          Looks sick
          • #35
            Looking good! Should give me your close off panel since you cant use it anymore
            • #36
              Geez you might be able to drive this thing this year!
              • #37
                Looking good!
                • #38
                  No, actually Spencer I'm going to try and modify it to fit around the pipe. Thanks!
                  ------ SOLD ------
                  >>> NSTYHBT <<<
                  • #39
                    Slow going this week but I did manage to get the Derale fans installed.
                    Now time to fab a close-out.
                    ------ SOLD ------
                    >>> NSTYHBT <<<
                    • #40
                      Mounted trans cooler and took care of other small stuff today. I had to re-form the washer bottle a little in order to clear the trans cooler.
                      Received package in mail today. Used but a smokin' deal.
                      Hopefully this will take care of my rock hard front end.
                      ------ SOLD ------
                      >>> NSTYHBT <<<
                      • #41
                        Damn this is moving fast looking good!!!
                        • #42
                          Looks ok I guess.....
                          • #43
                            • #44
                              What's the spring rate on your coil overs? Mine were 175 and I bottomed out on everything, now run 315 and love it.. I have the same shocks, mine were converted to "R" series..
                              • #45
                                Larry, these are 275's. so I guess we'll see how they ride and hopefully they won't bottom out. What does that mean by converted to "R" series?
                                ------ SOLD ------
                                >>> NSTYHBT <<<
