Huron Speed A/C Turbo Kit - Another Reason to Tear Into It
  • Originally posted by Superman09 View Post
    damn good base numbers! What dyno was this on? If that was the case, I am betting we will see a higher number on 8psi
    Dr. Phil tuned and ran it on the dyno which I think is at a shop on VanDyke near Hall Rd.
    ------ SOLD ------
    >>> NSTYHBT <<<
    • That's where we do the dyno day every year that Jeff organizes.
      • Ok, let's get this turbo install thing wrapped up!
        Turbo cooling, the final piece of the puzzle - Even though it is oil less turbo, coolant needs to be run to keep temps down. So, instead of running lines to the block, I decided to tap into a heater hose in series to make for a good circulation in and out and also allow ease of installation.
        So, I looked high and low for a fitting that would allow me to connect a -8an to a 3/4 barbed fitting, but I could not find one in this world!
        I called on my good friend to make these two fittings work for me and it came out better than I thought! A little paint and they are done.
        ------ SOLD ------
        >>> NSTYHBT <<<
        • So he took the two pieces and combined them into one? That's awesome.
            Yes, it worked out nicely.
            Well, what do I do now? I'm all done with the turbo install (almost).
            Looks close, but there is some clearance between there.
            ------ SOLD ------
            >>> NSTYHBT <<<
            • This is the worse project and poorest attention to detail I have seen. You should just hide it in my garage so the world can't see what a Frankenstein you have built. For shame, I will even give you some gummy bears just to take it out of your hands.
              *whistles*
              Originally posted by Yoshi94
              • That looks great. Almost finished in no time.
                • Next up..........
                  Front suspension and try to make this functional:
                  ------ SOLD ------
                  >>> NSTYHBT <<<
                  • Originally posted by BlackBirdDaddy View Post
                    Originally posted by JasonH
                    • Couldn't have asked for a nicer job! Terrific Jim!
                      • Well, I'm going to attempt to make this sway bar work, hmmmmmmm..............
                        ZR1 Blue. OMG, is that factory paint expensive!
                        ------ SOLD ------
                        >>> NSTYHBT <<<
                        • Expensive, but those calipers looks great! I like the blue color "pop" without being really bright and attention-whorish.
                          And, now I see the issue in the suspension. I didn't really follow why re-fitting it would be a challenge. Can you run some spacer blocks - possibly reinforced by gusseting or otherwise tying them in elsewhere for stability?
                          • I am thinking we can make a bracket for that sway bar very easily. 1-piece that bolts to the factory location and leaves a spot for it to mount in the new lower location!
                            Calipers look great!
                            • Calipers look AWESOME...I can't even imagine what that cost...
                              Just a question though, why do you need a front swaybar?
                                Y
                                I bet a lot of people look at shows and won't even notice theres a turbo in there. Nice Job!
                                — Thomas Jefferson
