Spray that *****
  • http://www.youtube.com/watch?v=_wu4K...ature=youtu.be
    2000 Formula
    fixed slow junk
    • Nice run!
      • Jim, are you going to be ready for next weekend?
        2000 Formula
        fixed slow junk
        • So if I best that 10.79 this year will you swap to an auto?
          • Autos suck
            • Haha - I'd love to go 4L80 or a th350......just not in the cards.
              My guess is - it'll go quicker next time out.
              2000 Formula
              fixed slow junk
              • Originally posted by Nocooler View Post
                Gonna try for the 13th if not the 20th. Everything seems good with car just need to stop working so much and get a few more miles on it!
                • Just made some changes to the wiring so the kit won't come on when the clutch (2-step) is in.
                  Hopefully that'll help me get the 60' dialed in.
                  2000 Formula
                  fixed slow junk
                    How did you do that if you don't mind me asking
                    2015 Silverado
                    • Relay.....inline with the power switch.
                      Clutch switch has power until the clutch pedal is pushed.
                      tap line and hook it to 86 on the relay
                      85 goes to ground
                      87 - power from activation switch
                      30 - power to solenoid relay
                      Clutch out - relay is active - clutch in, it interrupts the power from the activation switch.
                      I'm sure there are many different ways to do it - it's just what I came up with quickly.
                      2000 Formula
                      fixed slow junk
                      • 2 bottles full for sunday
                        2000 Formula
                        fixed slow junk
                        • Bumping the thread - I'm getting the itch to get this thing out and hammer on it.
                          Recap - gained 10mph on 100shot and 13mph on 150shot.
                          Changes this year
                          Adding an inline nitrous filter - as current filter just protects my N20 noid and my purge ate some trash
                          Replacement purge noid
                          Installing the poly engine mounts that I've had for 4 years.
                          Since the headers are coming out - I might wrap them, too keep the temps down and maybe allow me to pull a plug or 2 after a short cool down.
                          Improved Racing Oil pan baffle - might as well try to control the oil, pressure is pretty sad until the cars settles around the 1000' mark
                          While the pan is out it'll get a new gasket and I'm going to replace the oil pump o-ring, just for giggles.
                          Hoping the stock short block will hang in there for another couple seasons
                          When it's done the plan is to make a few passes - see where it's at, pull a couple more degree's of timing and lean the ***** out
                          2000 Formula
                          fixed slow junk
                          • I'm getting the itch too!!!
                            I highly recommend the DEI Titanium wrap. I can touch my crossover pipe right after I shut the car down (I can't hold my hand on it...but I can touch it). Plus the stuff is easy to wrap and looks great!
                            • That's the stuff I was going to run
                              2000 Formula
                              fixed slow junk
                              • Boxes of parts on the way
                                I think I'll end up putting a flowmaster merge on it while it's apart....or maybe some 6" bullets and turndowns off the headers
                                2000 Formula
                                fixed slow junk
