aim the rotor to where you are gonna put the #1 plug wire. then look at the bottom of the dis and see where the oil drive slot is. Can be a pain to line up.
Or get the rotor close( have to take into account it turn some while sliding in) then bump the engine over> the dist will eventually align itself with the oil pump.
Depending on cam material, roller or flat the gears are diff becuase non roller cams have lobes that turn the lifters in the bore, which also pushes the cam forward which will cause wear to the wrong gear
Ok can anything possibly be wrong or just me? I hope its just me, I am going to have Jon take another look at it, but I picked up a stock Distributor from Brian's 85 and still cant get that to drop in place.
To keep the fraying to a min. Wrap a piece of electrical tape tightly around the hose. Then cut the hose right through the tape with a cut-off wheel. You can keep the tape on the hose and insert that into the fitting.
