Originally posted by TylerT/AZ28
View Post
Post Whore
- November 8th, 2009
- 3000
- Tyler Porter
- 85 Z28, 91 Trans am
- Clinton Township Michigan
- student
had them out last week. no problems91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
00 Tahoe Z71........Stock
Post Slut
- December 9th, 2011
- 5919
- Michael H
- Lowell, MI
- Meat Processor
I like the Stage 8 stainless header bolts I put on my Iroc. Pricey, but I think it was worth it to know they won't back out.
Initially on the Malibu I installed the fancy metal type crushable header gaskets supposed to be the best money can buy. Could never get them not to leak. Installed el cheapo paper header gaskets that came with the headers and haven't had a problem since. So in my case the fancy gaskets were actually the problem. Just my .02
1978 Chevy Malibu Classic: 350 Crate Swap, Turbo 350 Transmission, Flowtech Full length Headers, Flowmaster 40's Mufflers, Tru-Dual Exhaust, Goodmark 2in Cowl Hood, Northern Autoparts Racing Aluminum Radiator, Jasper Pearl Paint Job, Billet Specialities Vintec Wheels
1994 Chevy Camaro: Sold
Former Projectcamaro Member
Well crap... All header bolts where nice and loose, every single one. The passenger rear two bolts where so loose they came out by hand... Solutions? I tightened them all back down leak is gone car ran great... Will they just back out again?
Now on to that crappy oil leaksigpic
I used these on my headers and haven't had to tighten them up once this year: http://www.stage8.com/sigpic
Post Slut
- 5919
- Michael H
- Lowell, MI
- Meat Processor
That's what I run, worth the money. Do them once and forget about 'em.Originally posted by ryanwarby01 View PostI used these on my headers and haven't had to tighten them up once this year: http://www.stage8.com/
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
Maybe the bolts are just a little long and when you tighten them they are also bottoming out, next time you tighten them slip a regular washer or a lock washer between bolt head and header or both..sigpic
Thanks guys I'll look into those bolts...
Didnt think of this. I'll check it out next time I'm under the hood.Originally posted by Plum Nuts View PostMaybe the bolts are just a little long and when you tighten them they are also bottoming out, next time you tighten them slip a regular washer or a lock washer between bolt head and header or both..
What do you guys use to reattach the headliner to the car? What type of glue? Mine is starting to come down, t tops off all the time will do that.
Child labor anyone?
So I need a clutch, after talking a little with Brian I am sure that's another issue my car has... Great. I have still been driving the car, I can just tell its starting to slip, not bad unless going on the highway at 85MPH+
Talking with Brian about clutches, and what I should get, thinking maybe just a stock replacement or maybe something a little better, any opinions?sigpic
Post Slut
- 5919
- Michael H
- Lowell, MI
- Meat Processor
I think I went with some cheap organic HD clutch. Mainly because I wanted it to be the weak link for now...I'd rather burn up a clutch than explode a trans or rear end
good to know...since I assisted in putting those clips onOriginally posted by ryanwarby01 View PostI used these on my headers and haven't had to tighten them up once this year: http://www.stage8.com/'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
