Originally posted by WMCC Gary
View Post
The car is getting a white grill that is for sure this winter...sigpic
ok running into a couple issues with the car. First I have this terrible header leak that has seemed to come back from last season its really pissing me off. Is it possible that this header is warped? Second, also header related how can I better protect my wires from being fried all the time, I am tired of replacing wires! I already asked Bri and he said something about wire sock? Need to wrap my headers as well? I have tried re routing the wires a couple different ways, cant seem to find something to protect them better.sigpic
I had a header warp on my gto warp once. Gave me a ticking noise that drove me crazy. Ended up just replacing the headers and fixed the problem. I use these on my plug wires and have had zero issues: http://www.oreillyauto.com/site/c/de...1810&ppt=C0379sigpic
Post Whore
- November 8th, 2009
- 3000
- Tyler Porter
- 85 Z28, 91 Trans am
- Clinton Township Michigan
- student
what about some thick wire loom?91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
00 Tahoe Z71........Stock
I am going to re check again tomorrow night (anniversary today) but I tightened them up again on sunday, drove the car 1.5 miles and the leak was worse then before... I think something else is up and its not just going to be a "easy" fix. I think new long tube are in order which = a new exhaust. However I am now torn if I should just pull the motor. I really wanted to enjoy it for another month tho...Originally posted by MP81 View PostAre your header bolts tight? I know I always had one bolt that would never stay tight on my Edelbrocks on my IROC. Didn't leak though.sigpic
Happy anniversary man!Originally posted by Darren View PostI am going to re check again tomorrow night (anniversary today) but I tightened them up again on sunday, drove the car 1.5 miles and the leak was worse then before... I think something else is up and its not just going to be a "easy" fix. I think new long tube are in order which = a new exhaust. However I am now torn if I should just pull the motor. I really wanted to enjoy it for another month tho...
Hmm, so perhaps it sounds like the header gaskets then...have you pinpointed the area it's leaking out of?Gone but not forgotten: 1986 Chevrolet Camaro IROC-Z
Thanks, and yes. It happened at the end of last season, I pulled the bolts and replaced the header gaskets as well as the header bolts. Now it is doing it again from the same spot, the passenger side all the way back on to the fire wall.Originally posted by MP81 View PostHappy anniversary man!
Hmm, so perhaps it sounds like the header gaskets then...have you pinpointed the area it's leaking out of?sigpic
Hmm, interesting...maybe pull that header and make sure the face is true?Originally posted by Darren View PostThanks, and yes. It happened at the end of last season, I pulled the bolts and replaced the header gaskets as well as the header bolts. Now it is doing it again from the same spot, the passenger side all the way back on to the fire wall.Gone but not forgotten: 1986 Chevrolet Camaro IROC-Z
Post Whore
- 3000
- Tyler Porter
- student
lock tite and lock washers.91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
Locktite the header bolts into the heads?Originally posted by TylerT/AZ28 View Postlock tite and lock washers.
I believe they have lock washers, I would have to check to confirm tho.
Yeah I'd be afraid of the bolts getting stuck in the heads.- Brian Meissen
exactly my thought, more likely the header is warped, or how often do these header bolts want to back out?Originally posted by meissen View PostYeah I'd be afraid of the bolts getting stuck in the heads.sigpic
Post Whore
- 3000
- Tyler Porter
- student
my friends truck headers just didnt like his heads, the bolts kept backing out, put them on mine when i had it and they were as snug as could be, so we put some locktite on them and they are still holding strong.91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
