Originally posted by 85z28kid View PostWow!!! I'm retarded I read to many threads and forgot things lol. What do you need to know about the air then if it's not there already?
reading owns you.
The AIR system, the ugly pump and vacuum lines and such that is on the drivers side of the engine bay up close to the head light bar. I'll shoot a picture this weekend when I start removing it all. Most of my lines and such for the emissions is already blocked of or removed.sigpic
and a big hack hack there ^^Originally posted by 85z28kid View PostI already yanked all mine out lol when I swapped to carb. It was easy A little snip snip there and a little chop chop there.
Post Slut
- December 9th, 2011
- 5919
- Michael H
- Lowell, MI
- Meat Processor
Very easy to do. Remove the pump, replace with idler setup if you want to keep the same belt and routing. Or swap to a smaller belt and re-route. If the tubes are already gone all you should have is two connectors from the harness left.
I dont think we are all on the same page here, the stuff I am talking about has nothing to do with the serp setup. I have already removed the AC and SMOG pulleys and my serp setup is about ready to go back on. I am talking about the canister in the drivers side of the engine bay. See the crappy picture below.
photo.PNGsigpic
Post Slut
- 5919
- Michael H
- Lowell, MI
- Meat Processor
That isn't AIR, but it is part of your emissions. All it does is pull the fumes from the tank and purge them into the intake.
I really need the brackets and bolts that mount that canister to the car!
yeah I guess calling it the AIR pump was bad because that is the same as the SMOG but this is apart of the AIR system or emissions all the same thing. Most of the shit is blocked off already, so its not needed correct? I will be removing it this weekend I can save the brackets for ya, worth a couple bucks? I dont know. Since your already coming by the house.Originally posted by hoogiesngrinderz View PostThat isn't AIR, but it is part of your emissions. All it does is pull the fumes from the tank and purge them into the intake.
I really need the brackets and bolts that mount that canister to the car!Last edited by Darren; January 12th, 2012, 10:48 AM.sigpic
I m sure it for sell if not I'll sell it to uOriginally posted by hoogiesngrinderz View PostThat isn't AIR, but it is part of your emissions. All it does is pull the fumes from the tank and purge them into the intake.
I really need the brackets and bolts that mount that canister to the car!The Original
It'll be gone tomorrow!Originally posted by jetice View PostCharcoal Canister, does what Michael said. Let it fly!!!!sigpic
Post Slut
- 5919
- Michael H
- Lowell, MI
- Meat Processor
K. I have a brand new canister, just no way of securing it and having it stock. You can sell that on ebay for a few bucks, I just need the metal off the bottom and the bolts.
TBI or carb? There should be three lines coming up the driver side frame rail - feed, return, and vent. I'd run a line away from the exhaust and then top it with a small vent filter.
I have headers...
