I wouldn't recommend using scotch brite on the mating surfaces Mike, I was always told do it by hand and gasket remover and a plastic ice scraper work wonders, you can also use a razor blade but use caution.
Yup, 3 jaw, hooked to the CENTER, if you try to hook it to the outside where the belt rides 1 of 3 things happens, if the puller flys off, it breaks the lip, or it separates the outer ring from the inner one. None of which is the optimum scenario, lol. Theres 3 little like tabs that worked good for me.1999 Camaro - 6 liters of fury.....
even with the motor pulled out, 3 jaw puller, and an impact, it was still a *****, lol. hope putting it back on is easier.
well got my rear diff home today after the fresh rebuild and installation of the oe 3.73s. will probably reinstall it tomorrow night. i need to declutter the garage so i need to install some partssigpic
- - 5.3/4L80e/T7875 - -
- Huron Speed Turbo Kit -
1998 Formula
you just need a nice 3 prong puller, I have a great setup but im too far away.Doing less with more
well today i re-installed my rear end with "imagegtp" (cousin robb). went in without any issues, except i pulled the wires out of the traction control sensor plug when i plugged it in to early and the rear shifted and pulled the wire to tight, so i have to fix that once i figure out which connection they came out of, DOH!. its nice to see the car start coming back together though, even if its something simple like that, lol.
we started attempting to replace his intake manifold gasket on his GTP and found we didnt have a gasket for the supercharger, so his will sit overnight and we will finish it up tomorrow.sigpic
1998 Formula
InActive Member
- November 19th, 2006
- 527
- dustin
- 1989 camaro rs, 2002 gmc sierra 1500,1999 chevy tahoe 2dr lifted
- rothbury michigan
- automotive technition
3-jaw puller hooked to the inside of the pully?
