ok everyone im going to start researching products for my winter modifications so i need some help. im new to cam swaps and cylinder heads, something i have never gotten into.
my plans are cam, heads, stall, and gears
i have a 5.3 sitting in the garage i want to steal the heads off of. i know they need to be ported and new, bigger valves installed to be better then my stock 98 heads. anyone have a link or exact instructions on exactly what needs done? if i cant make these work ill probably just wait until i can afford some good ones. i know these heads raise the compression ratio, which will make more power.
so that leaves a cam and its necessary parts. if its going to be a cam only motor, what size and where should i start looking? i want a lumpy, useable cam. something that will sound most excellent at idle, yet still scream when opened up. is this possible? i will need valve springs and rockers possibly but read that the stock rockers will work if the cam isnt to big. do i need pushrods, yes? what brand/where?
i have a LS6 timing chain and ported LS6 oil pump already
i have a stall lined up and gears, just know one to do the gears yet. im thinking of tackling the gears by myself. any thoughts? im installing 3.73s
also once this is done, i know it needs to be tuned. will the car be safe to start and drive being untuned or should i trailer it to be tuned?
cash will be a big player in this so im trying to do this cheap as possible, but not cheap enough to where it will need to be done again.
im hoping to have this done by spring so any help would greatly be appreciated. thanks
