Worked on the engine a bit last night.
I got the manifolds of and the stock y pipe and cat. Do I need to make a block off plate for the back of the intake where the egr went in? Will a little bit of rtv and some sheet metal bolted in work?
Had to use a good old trusty pipe on the end of the ratchet.
0 bolts stripped nor broken, well except the ones that hook the y pipe to maniflods but that isn't really an issue.
I am going to assume these vac lines broke while we were taking it out, because wouldn't it give me a idle issue?
I pulled 2 or 3 plugs out to see what they look like, this was the worst of them all. Not sure, put pretty sure the previous owner before I originally had it put new plugs and wires on it and also a opti, do you think I should still replace the opti? It looks like crap but works great.
And last but not least, I traded my clears for some stockers, here is the before...
And... the after....Just needs a bit of wet sanding and wheeling and they should look pretty nice!
Didn't get any pictures but I also removed the A/C....
Buddy and I are going to work on it again tonight, what should I do next? Water pump and opti and wires? Intake? My dad made some pretty good chili that we are going to dig into when my buddy and I get over to my house so we might not have much time to work on it on account of having to "do work" .. if you know what I mean
lol
Any suggestions?
BTW thanks Larry for the heads up on it being cheaper to buy stuff seperatly.
Thanks Mike for the stock parking lights and the prices on gaskets.
Any suggestions?
