  • The K&N CAI comes with a "filler" piece for 1993 cars.
    You can have mine if you want.
    1996 Base Model
    +2 cylinder mod
    • Originally posted by jderry View Post
      Can I swing out your way tomorrow night? Or Saturday? Shoot me a pm. Thanks
      I picked up a new temp sensor, a few band clamps. Also got 2 drain plugs for the ory bungs.
      I went to install the exhaust and realized my dyslexia ass ordered 3.5" od x 3" id reducers instead of 3.5" id x 3" od... Grrr...
      Found out my oil leak is coming from the oil filter. Hopefully it's because I put it dry on dry. I'll be changing the oil tomorrow night and putting a new filter on after we adjust the rockers.
      Still need to do the rear lowering springs
      2002 Z28 Camaro A4
      • Never put an oil filter on dry. Also put some clean oil on the o-ring. When you take it off now, make sure there is only one gasket. It will leak if the old gasket was still on and you doubled up the gasket.
        Originally posted by Yoshi94
          Any other time I fill her up with oil and lube the seal a bit but the filter has been on for awhile and wasn't even expecting to run this filter.
          2002 Z28 Camaro A4
          • We have done it both ways, I did the 8 and 8 method on mine. Hard part is feeling drag on push rods since you really don't have oil in the lifters. On B's car we did it before the intake was on so I could watch the top of the lifters, I thought that was easier.
              I wish I could spray everything all at once but I want the least amount possible in the booth with the car when I spray that. I'm using the same gun and it's all coming from the same gallon of paint, same color sealer too. Plus even bumpers from the factory on brand new cars don't match worth a broke dick lol. I think I should be ok. But I know where you're coming from.
              I know what you mean there. When I sprayed my car I did all the gfx bumpers, mirrors, spoiler etc separate. Then the car the next day. It looks good but with metallics it will never be perfect. Most of the time the smaller piece even bumper covers tend to get more base coat/ paint cause they are a smaller piece then when you are doin the whole car.
              • Got the front bumper sprayed today. Ended up keeping the bottom ppm.
                Took it for a spin. It hasn't seen 45mph in 2+ years... Then I realized I only had 3 lug nuts on each wheel. Luckly I remembered this before disaster.
                Oil leak fixed itself. My temp guage only got to the 2nd hatch mark on guage?
                My trans is acting up. It won't engage into park. We attempted to fiddle with the shifter linkage but it won't go in to park unless we physically push the nob going in to the trans forward. I'm going to ask trans guy what's up with that. She does great burnouts. I only did a baby one.
                Correct reducers will be in Monday.
                Installing rear springs Monday also.
                Edit: adjusted the rockers. It went well. Tightened up ds bolts. Dropped the trans a bit to tighten the trans lines. Put belt back on. Checked for leaks. All is good
                2002 Z28 Camaro A4
                • Picked up a set of new black locking lug nuts.
                  Also picked up part of the missing link for the cai. Thanks (jderry) another great member!!
                  I still need a 3.5"-4" reducer
                  2002 Z28 Camaro A4
                  • bumper looks awesome!
                    • Looks like you do damn good work. I wouldnt worry about parts being painted at different times. This thing is going to look NICE. I would have did the fog light area in black though.
                        Thanks Joel. I love the gloss black buckets!
                        Thanks Nate! I can't wait to bring this to the m&g!!
                        2002 Z28 Camaro A4
                        • Car looks great! Can't wait to see the whole re paint
                          • Glad to help get an LT1 on the road =)
                            1996 Base Model
                            +2 cylinder mod
                            • paint looks incredible!
                              • EDIT: sorry guys, didnt realize how crappy the quailty is coming from my iphone.
                                id.
                                2002 Z28 Camaro A4
