  • I do believe the T56 mod will fix the park related issue.
    • To my knowledge there is only one hole. It's just your standard stock floor shifter, it's never been off the car to my knowledge.
      2002 Z28 Camaro A4
      1993 Z28 Camaro M6- SOLD
      1999 Z28 Camaro M6- SOLD
      2008 Ford Fusion SE - DD
        Still needs some minor adjustments but I think it's just about set
        Tomorrow we are bleeding the brakes, doing the rear lowering springs, finishing up the exhaust, putting the hood on and hopefully figuring out the park issue. Is there an adjustment for the cable?
        There is an adjustment where the bracket bolts to trans. the are two nuts that you adj to move cable back or forward to get into Park.
        • With your car being a 93, it might be slightly different since you don't have the 4L60e.
            I was thinking the same thing. I don't recall anything being there. Hmmm. I'll have to take a look at it on my lunch break.
            2002 Z28 Camaro A4
              That it would, but I don't think it would be the most cost efficient way
              We got the rear springs in.
              Pulled the oil filter off, found some surface rust on the block. Cleaned that up, went to put new filter on.. Wrong one. I'd sure like to run a parts store and see what the big deal is on getting the correct parts the first time... Grr.
              Hopefully that fixes my oil leak.
              Tied back a few loose wires around the lts.
              2002 Z28 Camaro A4
              • Do you got your oil cooler deleted? If so you need a different filter than stock. Ac Delco number 1218, WIX 51060.
                2015 Silverado
                • Originally posted by Boost Addict View Post
                  I don't think it ever had a stock cooler.
                  The filter I had fit fine, he just gave me the wrong one this time around.
                  Also, my temp guage on my dash still isn't going past the first mark. Installed a new temp sensor on drivers head. Has brand new t stat.
                  2002 Z28 Camaro A4
                  • How long are you letting it run? It might just not be warming up that much or maybe you have an air pocket in the coolant.
                      Wix 51061 also fits. Same as the 51060 but one doesnt have a reverse flow check valve which our vertical filters dont need anyway
                        I have driven it about 2 miles. I figured it would be up to temp by then. Wouldn't an air pocket cause it to over heat, not stay "cold"
                        2002 Z28 Camaro A4
                        • My car takes about 3 miles before the temp gauge starts moving after i pull it out of a cool garage. What tstat?
                          • 160. I figured it would at least get past the first line
                            2002 Z28 Camaro A4
                            • There was a bit of surface rust on the block where the oil filter seals. Cleaned it up with a scotch brute and some steel wool. Got a new filter, changed the oil to some break in oil and the leak is gone. Pshew
                              Drove it about 5 miles today. The temp guage got about halfway. I didnt even think of the fact i didnt have a hood nor a bumper on. I bet its cooling it down quit a bit. Will i be okay driving it around until i get my trans cooler on in a week or so? Going to put much more on tomorrow. I can't wait! Bodywork is getting done Wednesday and Thursday night, then spraying it next weekend.
                              I'm still having issues with park. Currently P is R, R is N, N is D...
                              I got the night painting position!!! I should easily double my income! I can't wait! I start June 1st
                              2002 Z28 Camaro A4
                              • I have a 160* stat and it only goes half way between the 160* and the next line.
                                It is about 80c which is 176f. Remember a t-stat is rated for when it starts to open up.
                                Originally posted by Yoshi94
