  • Ryan hooked me up with k&n cai today. I can't express how thankful I am for some really stand up guys on this site!!!!
    Ryan also explained how to adjust my rockers. Should have a good video for y'all this weekend.
    I may be moving up at my job by the end of the month so I can't wait!!!
    Trying to save this thing!
    2002 Z28 Camaro A4
    • Dang, looks like a lot of work went into that piece. Looks pretty straight and even now though.
      What else do you have left body wise?
        Both quarter panels, one fender has a crack on the inside lip. I'll be repainting the whole car. Shooting for body the 25th and paint the 26th (of this month)
        2002 Z28 Camaro A4
        • You should up the metal flake just a weeee bit to add some more depth to the color
            I originally thought about it but a few reasons I stuck with stock mix:
            Didn't want to get away from stock color
            If I ever sold it or got into an accident the body shop would be mixing up the color wrong
            The rear bumper and Berger panel are already sprayed
            2002 Z28 Camaro A4
            • Does anyone know the bolt size I need to plug an O2 hole in the ory?
              Should I spray my head light buckets gloss black or keep them a semigloss look? Also, should I spray the lower center part between fogs black or leave body color?
              Anyone have a lower air dam thing laying around? How about some balck lug nuts? Also need a center cap for a zr1 wheel.
              2002 Z28 Camaro A4
                I like the black accents on the lights/grille.
                • I think it looks best as it came from the factory but with a high gloss black.
                  • lookin good but with that metallic color id be worried about color match, painting all thoes pieces seperate.
                    • Originally posted by Curt_irocz View Post
                      I wish I could spray everything all at once but I want the least amount possible in the booth with the car when I spray that. I'm using the same gun and it's all coming from the same gallon of paint, same color sealer too. Plus even bumpers from the factory on brand new cars don't match worth a broke dick lol. I think I should be ok. But I know where you're coming from.
                      2002 Z28 Camaro A4
                      • Id do everything possible to spray it all at once personally
                          With a full repaint, it's near impossible with your average size booth. Plus when you are clearing your last part you risk overspraying onto your car or visa versa, unless you are using really slow hardner. Plus you have to worry about the extra dirt coming off your stands and underside of bumpers dragging the hose that much more.It can be done, just a bitter sweet situation.
                          2002 Z28 Camaro A4
                          • What are you 93 fellas doing for your cai? I need to fill this gap lol
                            Got the 315's on. No bfh needed.
                            2002 Z28 Camaro A4
                            • You could do this...
                              http://www.ebay.com/itm/Universal-Bl...dc4614&vxp=mtr
                              • 17 or 18mm toyota drain plug But I do believe I used a M18x1.5 for my ORY its a drain plug for a toyota. I snagged a few from work
                                Dorman 65220
