Glad I did get a moment to stop and look at your car, Paint look awesome and the whole car came out great. Good Job!
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
I wanted to hunt you down but figured you had your rounds you wanted to make and had plenty to do when you got there. My girlfriend said you waved on the way out. Glad you guys liked itOriginally posted by meissen View PostCar look beautiful yesterday, Mike. Sorry I didn't get a chance to really talk to you. We were tallying up the votes as you left, we all had to stop and drool for a moment while you pulled out of your spot.
Thanks again Larry for everything! Brian, you have yourself a great father! Real down to earth guy!!!Originally posted by Plum Nuts View PostGlad I did get a moment to stop and look at your car, Paint look awesome and the whole car came out great. Good Job!2002 Z28 Camaro A4
1993 Z28 Camaro M6- SOLD
1999 Z28 Camaro M6- SOLD
2008 Ford Fusion SE - DD
Mike, your car looks awesome! It was great getting to see it at the m&g. Nice job on all the hard work getting it done to make it there!sigpic
Thanks Ryan! Couldn't of done it without your parts.Originally posted by ryanwarby01 View PostMike, your car looks awesome! It was great getting to see it at the m&g. Nice job on all the hard work getting it done to make it there!
Your car looks amazing, I love the stance and I bet it moves out nicely too!2002 Z28 Camaro A4
Haha sounds like an easy fix at least. Nice "fixed" pic
Not sure if you know but there is a way to route the plug wires behind the accessory bracket so they aren't near the belt. You can't see it from any angle with the engine in the car, you have to just feel around and you'll find it.-Joel
I couldn't find the 4 wire 90 degree clip originally or it wouldn't of happenOriginally posted by JoeliusZ28 View PostNot sure if you know but there is a way to route the plug wires behind the accessory bracket so they aren't near the belt. You can't see it from any angle with the engine in the car, you have to just feel around and you'll find it.
http://shbox.com/1/accy_brkt.jpg2002 Z28 Camaro A4
You don't need those
The wires can go straight back behind the bracket right from where they connect to the opti in the picture. Safer than the factory routing anyway.-Joel
Any suggestion on gear brands or the go to place for them?
http://www.texas-speed.com/p-2626-mo...-rear-end.aspx
Which "install" kit should I go with?
http://www.texas-speed.com/c-1279-ge...tall-kits.aspx2002 Z28 Camaro A4
Motive is definitely a good brand to go with. The 2 series gears are a little harder to find. The 3 series gears are only $150. Summit had them a little cheaper:
http://www.summitracing.com/parts/MGR-G875373X/Last edited by ryanwarby01; July 8th, 2012, 12:03 PM.sigpic
Just found some on jaws website for $189
http://www.jawsgear.com/Ring_And_Pin...52df5f88a99f38
Edit: that's for the 3 series... 2 series are $209.2002 Z28 Camaro A4
Wouldn't thicker be better?Originally posted by c0ncEpT View PostThe 2 series are a thicker gear set so they are going to be more expensive. You could always change the carrier. Might be able to score one for cheap/free somewhere.2002 Z28 Camaro A4
The 2 series ring gear flange is offset more to the left to accomodate the larger diameter pinion gear of the higher ratio. I don't know if one is actually stronger than the other, I would guess not.sigpic
