Originally posted by mcalus
View Post
ThanksOriginally posted by ryanwarby01 View PostWhen this color first came on these cars I didn't like it, but now that you don't see it very often, I do like it. Project looks great!
Which is which one?Originally posted by c0ncEpT View PostThe largest one that will physically fit in the area you have.Last edited by mcalus; April 17th, 2012, 08:07 PM.2002 Z28 Camaro A4
I never thought I'd say this but, the motor is in!!'
It was too dark to get any worthy pics but it went pretty smoothly.
The steering shaft is about a paper thickness away from the lts. I like the stance of the lowering springs. We got the k member bolts in, trans crossmember, steering shaft and brake lines. We accidently stripped out one of the brake lives to the main distribution block :/ looks like I'll be finding a used one.2002 Z28 Camaro A4
happy to hear!
well done man, good work!sigpic
- August 16th, 2007
- 2881
- Jim
- Traverse City, MI
Congrats! That's definitely the most satisfying part of a project aside from the first start-up.
Thanks everyone! I'm sure I'll have some more questions ahead, you all have been a great help!!! I'll be knocking a bunch out Saturday.
WOOT!2002 Z28 Camaro A4
We got quite a bit done tonight.
Installed/hooked up:
Radiator
Condensor
Fans
Injector wiring
Intake mani random connectors
Coolant hoses
Power & ground cables some what routed
Alt power/connector
Header panel / headlights
I'm sure there is more...
Some connectors fall into place, others are like where the f$&k does this go!? Lol
For some reason I can't seem to find the coolant temp sensor? Wire that plugs into the drivers head. The main ground seems to be tricky. We still have 3 "open" tubes on the water pump (pretty sure at least 2 are for heater core)
Also, there are the 2 fuel lines, then the one vacuum type line, I believe it connects to passenger side if intake but it seems difficult to route.
Hmmm I'm sure I'm missing things. It's late. Gotta work in am :/
Hope this doesn't post as one big paragraph, I'm on my iPhone.
2002 Z28 Camaro A4
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
good progress, we should hear this running by sunday?
OBTW Inline tube will make up break lines, they have cad spec's for cars will pre bend and flair them up for you. Inline tube is in Shelby twp. 22 and Hayes area.sigpic
I think I should be good on the brake lines. Thanks!
Noob question, can I start the car without trans fluid? I am NOT taking it out of park. Does the convertor have to be bolted to the flywheel to start it?
I'm just trying to find out what the bare minimum will be to start her
2002 Z28 Camaro A4
I would not, I know you said without the converter bolted up, however, I do not think that is a great idea. I would bolt the converter up and put fluid in it because anytime the engine is running the transmission pump would be turning also.sigpic
1996 Base Model
+2 cylinder mod
Make sure you fill the converter before installing it and make sure it fully engages you should hear it click.Doing less with more
