  • Got the Bilsteins in today, gave the trans to trans guy, he said it looks to be a pretty nice kit.
    Ordered a new low oil sensor. $22, will be in tomorrow.
    2002 Z28 Camaro A4
    • Random thought but has this trans guy had much experience with the 700r? Just hoping he knows what to do with those parts as I know Dana tends to do some unique things with some of his stuff.
        He seemed pretty confident. He said he has done a lot of them in his day. I have worked at two dealerships with him. One ge was the trans/clutch/rearend guy the current dealership he is one of 2 heavy mechanics, does motor swaps etc. He seems to know his stuff. Only time will tell I suppose.
        2002 Z28 Camaro A4
        • Coming along nicely. Everytime I pop in and check the thread, boom more parts. Jeez must be nice.
          Originally posted by Yoshi94
            I just really want this done for the meet and greet. Now that the 99 is sold I can't go a whole summer without a toy.
            2002 Z28 Camaro A4
            • Throw some money this way. I am collecting donations.
              EDIT:
              For the church or Kony what ever you choose to say is a legitamite reason to give me money.
                Throw some money this way. I am collecting donations.EDIT:For the church or Kony what ever you choose to say is a legitamite reason to give me money.
                I'll keep it in mind I have spent approximately, $4,526.I am guessing I have around $1,200 minimum to have it as presentable as I want it by the m&g
                2002 Z28 Camaro A4
                  Just ordered my Revmax 3600 stall
                  Should be in next week
                  I need to send my pcm out for a tune!!!
                  I had a pcmforless tune with my hotcam and it was pretty good. A dyno tune would have been better, but for $500 I didn't see the value for my set up. The LT1 tunes are more limited than what you can do with a tune for a LS1. If your under a budget, you could do a mail order tune to get you by until a dyno tune. Just my .02
                    That's what id really like to do.
                    2002 Z28 Camaro A4
                    • If it wasn't a 93 I could do the tune for you so you'd at least run. I don't have a burner for the chips or anything.
                        Its the thought that counts
                        I think I'm going with pcmforless
                        2002 Z28 Camaro A4
                        • I might get into tuning TPI and 93s.
                          • Got the new oil level sensor.
                            Noob question, does the white piece stay on? It it so the sensor doesn't get messed up or is it part of the sensor like a "float"?
                            2002 Z28 Camaro A4
                              It stays on.
                                It stays on.
                                Cool thanks
                                2002 Z28 Camaro A4
