Pretty sure I got all of mine off without cutting, don't recall having this issue but who knows my memory is shot.Doing less with more
Bought new end links.
Got the rear painted.
All cleaned up and grinded down a bit. I really wanted to go to town on this thing but for something that could break at anytime would be pointless.
I also have no clue what kind of LCA's I should get. I heard the non adjustable ones bind too much. Should I get the 3 piece ones? I really don't think I need adjustable but I could be wrong.2002 Z28 Camaro A4
1993 Z28 Camaro M6- SOLD
1999 Z28 Camaro M6- SOLD
2008 Ford Fusion SE - DD
I put a set of poly polys non adj on my 99 and didn't notice any difference over my stockers. But I wanna do them "while I'm in there".Originally posted by c0ncEpT View PostI'm a fan of poly on 1 end and rod end on the other for a street car. Some people perfer poly/poly tho
Suggestions on rearend fluid and weight?2002 Z28 Camaro A4
Lurker
- March 13th, 2010
- 3476
- TJ
- 1995 Chevy Camaro Z28
- Clinton Twp Michigan
- Powerline Tree Trimmer.
I have non adjustable poly/poly and didn't notice anything.
Considering stock was non adjustable rubber/rubber.
AMS Oil?
80w90?
By the way, looks like garbage panther pink would of been a much better choice.Last edited by Fox Slaughter; January 11th, 2013, 05:09 PM.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
You really wont notice anything directly when lcas are binding... You have to be driving the car pretty hard for it to have an effect (in corners) and at most its going to give you some wheel hop because it will be at odds with the shock/spring for control of the suspension.-Joel
Exactly why I did my LCAs... I was there. Ended up with poly/poly non adjustable founders ones. They're nice, but I don't use my car in the ways where you'd really need better LCAs. Just didn't want to put the old ones back in when new ones were so cheap. Though an on-car adjustable panhard bar is a must for wider wheels. And don't mess with anything that isn't on-car adjustable.Originally posted by mcalus View PostI put a set of poly polys non adj on my 99 and didn't notice any difference over my stockers. But I wanna do them "while I'm in there".
Suggestions on rearend fluid and weight?2000 Trans Am l 1967 Firebird
Already have the adj phb. So really I wont benefit from new LCA's. At least for a weekend/ nice weather car. I have also heard of guys putting moog bushings in the stock lcas but that sounds like a complete pain.Originally posted by Lucky SOB View PostExactly why I did my LCAs... I was there. Ended up with poly/poly non adjustable founders ones. They're nice, but I don't use my car in the ways where you'd really need better LCAs. Just didn't want to put the old ones back in when new ones were so cheap. Though an on-car adjustable panhard bar is a must for wider wheels. And don't mess with anything that isn't on-car adjustable.2002 Z28 Camaro A4
Lurker
- March 13th, 2010
- 3476
- TJ
Sounds like putting makeup on a pig.
Founders can be had for like what 100 for the pair?
EDIT:
I lied 63 bucks a pair.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Another thing I'll need to get so I can adjust the speedo-
http://www.dakotadigital.com/index.c...rod/prd126.htm2002 Z28 Camaro A4
Lurker
- March 13th, 2010
- 3476
- TJ
HoosierGrinds can burn chips.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
