I'm just going to get Joel a bra... he needs support.
Lurker
- March 13th, 2010
- 3476
- TJ
- 1995 Chevy Camaro Z28
- Clinton Twp Michigan
- Powerline Tree Trimmer.
Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
The differential girdle push-up bra, coming to a vickii's near you!-Joel
Lurker
- March 13th, 2010
- 3476
- TJ
I think before mike comes over tomorrow I'm going to throw a quick paint job on. I'm thinking a hot pink 10 bolt will be the sex.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
I think its all in your head Joel. While it works in theory its does nothing to help that the ring and pinion itself is grossly undersized for cars this heavy with this much power. It may help with a bit of deflection but its not going to stop you from removing every tooth from the ring gear when you drop the clutch at 5K and it hooks
I agree that a 7.5" ring gear is still a 7.5" ring gear no matter what you do to it. But what ive seen of gussetted rear ends, it does seem like there is some validity in making sure the ring and pinion stay in perfect alignment during hard launches.-Joel
You have a point and I agree it cant hurt at all. But how much time, effort, and most importantly money are you going to drain into the 10 bolt when all roads lead to a S60/9"/12 bolt.
Lots of ways to look at it.
Lurker
- March 13th, 2010
- 3476
- TJ
The deed is done.
Mike is currently driving back to Chelsea with a 10 bolt.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
This man speak the truth. (TJ, I'm leaving you feedback now)
Ill be dropping the old rear out tomorrow. Hopefully it will be nice enough for me to spray the rear and then the 3.42 rear will be going in Friday or Saturday.2002 Z28 Camaro A4
1993 Z28 Camaro M6- SOLD
1999 Z28 Camaro M6- SOLD
2008 Ford Fusion SE - DD
Lurker
- March 13th, 2010
- 3476
- TJ
Haha. I had to die grinder one of my sway bar end links.
So I need some also haha.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Is the stock rear sway bar 19mm? There are 4 options...
http://www.hawksthirdgenparts.com/pr...-Complete.html2002 Z28 Camaro A4
Really? That would be sweet. I don't need the bushings but it wouldn't be a bad idea. The clamps are still good, for now, I haven't pulled the sway bar off the rear yet.Originally posted by Lucky SOB View PostThey sell MOOG polyurethane end links for $8/link at Oreileys... At least they did 2 years ago. Do you need the clamps and bushings, or just the end links?2002 Z28 Camaro A4
Im going to have to replace my endlinks as soon as i upgrade my sway bar too. I remember I broke a 3/8 ratchet trying to take them apart to paint it... so i just left them on
Lurker
- March 13th, 2010
- 3476
- TJ
I just bought a 3/8th impact gun.Originally posted by JoeliusZ28 View PostIm going to have to replace my endlinks as soon as i upgrade my sway bar too. I remember I broke a 3/8 ratchet trying to take them apart to paint it... so i just left them on
My 1/2in that would do 625lbs wouldn't even move the one. I finally got around today to hooking up the 700lbs one I have.
But nothing the die grinder couldn't fix. Haha.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
