I guess now that i think about it pinion angle would have an effect on direction of the force applied to the lca. How that would affect things is still a little over my head though
Project: PBR-Built Z/28
ok looking at this some more, the tailshaft seems to be at 4* angled towards the ground. I know a few of you said that ideally the pinion angle should match the driveshaft angle, but that adjustment seems way out of spec per both the BMR and madman instructions. Is a few degrees out not enough to be a serious concern for u-joint friction/stress?
Right now I have:
.5* pinion (aimed up)
-3* driveshaft (pinion is below tailshaft)
-4* tailshaft (static, aimed towards ground)
this would be a 2.5* configuration which would be ideal per the BMR instruction. Wouldnt the madman style put more stress on the u-joints? Or does that angle get counteracted during a hard launch?
I also realized my pictures before may not have been clear. My pinion angle was positive, angled up towards the car... not the other way around like concept was calling for.-Joel
Joel - this is one of those things that everyone has an opinion about.
I've tried quite a few methods. The only one that worked without vibration on my car was midwest chassis's, but the pinion of the 9" is considerably lower than the 10 bolt.
http://midwestchassis.com/uploads/3/...nion_angle.pdf
Using midwest chassis's method you have -2.5* and are pretty close.
I'd drive it and see how it works. You can fine tune it from there.2000 Formula
fixed slow junk
Thanks Jeremy... I think I'll leave it as it is and see how it works.
Moving on to the front, just got the first strut out:
Brakes work perfect as they are... there is WAY too many things to be done before spring for me to even think about adding anything else.
I've always been a night owl. Its kind of amazing, I get 10 days off of work (and school) where I can actually operate on the sleep schedule I like (1am to 10am) and things magically start getting done! Normally id be wrenching til at least midnight but I drank a lot last night and will be drinking even more tomorrow
edit: and I definitely have the typical strut mount rust!Last edited by JoeliusZ28; December 30th, 2012, 11:11 PM.-Joel
Fuel pump and front springs have arrived! Now I am going to hurry up and ... wait for this cold to go away before i do anything
I hear ya! I want to scrap my 82- but I need to remove the suspension prior to scrapping it but its covered in snow. It too cold and windy to work outside, so that project is delayed until the snow melts and I can bring it inside.
I hear ya. I had huge plans this winter to get a lot of little odds and ends done, but in two months I still haven't finished my !AIR and !EGR. Too cold and kinda tough with the ankle biter and family/work commitments.Originally posted by JoeliusZ28 View PostFuel pump and front springs have arrived! Now I am going to hurry up and ... wait for this cold to go away before i do anything
- August 16th, 2007
- 2881
- Jim
- Traverse City, MI
Same boat here. Barely looked at my car in over a month. Between the cold and feeling like the day's over at 5:30pm I haven't been motivated to do shit after work.
After 9 days this freggin cold still hasn't let up!! So I decided to work on my fuel pump in the house today
Also my power steering cooler and fluid came in.
If anyone wants a stock fuel pump, I think that one I got from Jim still works, but I never confirmed. (pictured on the table above). Free if anyone wants it.-Joel
Lurker
- March 13th, 2010
- 3476
- TJ
- 1995 Chevy Camaro Z28
- Clinton Twp Michigan
- Powerline Tree Trimmer.
This is what I am starting. I need to get some metric impact sockets though. Can't get the panhard support bar off to drop the gas tank. Broke my regular sockets.
So hoping to have it out by this weekend.
Hard swapping the pumps?Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
I think its easy as long as the plastic bucket is in decent shape. My stock one was brittle so I remember I fubar'd it. This new sending unit i got from Jim was a lot better, plus i took my time... it was easy and turned out well.-Joel
Lurker
- March 13th, 2010
- 3476
- TJ
Did you get to plugging in the harness yet?Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
