"Shadowfax" - Jeremy's 15th Anv. Trans Am
    Does this car start and run? Turn over? Anything?
    The car turns over, and with a little help from mr. gas can.. it will start. I have another carb (more suited for this car) that I am going to rebuild.. just have to do it.. figured I would tackle the wiring first.. since its a mess.. and there is something grounding or shorting somewhere that is killing the battery like crazy.
    "Project Shadowfax" <- Clicky Clicky
    • Easy solution if your just going to rip the motor out. Tear the wiring down to the BARE bones... add a MSD setup wire that in, wire your fans to a stand alone system (like a painless kit) and boom running driving car... then rip it out when ready for the LS. I mean you wouldnt have heat/AC (if the car has it) or anything else like that but you could very easily get the car running.
      • I think that's a smart move Jeremy. Do what you need to to get the car running, but then focus more on converting it to an LSx.
        I can appreciate wanting to keep things original but the time, energy, and $$ spent doing that will become overwhelming.
        West Michigan Pontiac Club
          Well the ignition system right now is an HEI distributor.. seems like a pretty stand alone system the way it is haha! I mean I have an MSD HEI distributor that I could swap it.. but don't think it would make much of a difference.. the fans I haven't even considered yet.. ugh.. just like I haven't figured out yet what I want to do with the trans lockup situation.. the car doesn't have heat or AC the way it is.. so not a huge concern there haha!
          yea I was thinking about going original on it.. but I think it would be more effort than it would be worth (not saying I still won't hold onto the original drivetrain though)
          • Jeremy, seriously strip the harness down or whats left of it to the bare bones, hook up what you need and see how that thing runs! The fans and accessories are easily. It takes just a handful of wires to get the car to run. That is the single best mod I did to my car, I am glad bigjon [MENTION=2135]bigjon88[/MENTION] just cut the harness apart when I was terrified!
            • oh yea.. I have most of the passenger side harness unhooked (the computer harness).. but there is still a lot of crossover that I have to figure out what does what.
              • Easy I can do it if you need a hand
                • thanks guys! if I get stumped on it.. I may very well get at you!
                  • i tore mine out and after crying to darren that it was confusing as hell i just started depinning it after labeling went very smoothly
                    00 Tahoe Z71........Stock
                    • so I haven't moved forward with the wiring yet.. but decided to list everything up for sale that I am not planning on reusing.. couldn't believe how much stuff I had haha!
                      here is the updated thread in case anyone was curious -> sales ad
                      • So just a small update.. But I currently have my carb taken apart and is soaking with some cleaner
                        • I successfully ripped out all the wiring on the passenger side of the car.. Which is the computer wiring.. Started to go through the driver side engine harness.. And boy is it gross.. Most if the plugs are broken and super corroded.. And then a bunch of random spliced and loose wires.. Gotta print out my diagrams and really look at what's going on
                          • I have a box of 3rd gen wiring connections when I stripped mine apart. If need some let me know and I can check to see if I have it
                            • IT LIVES!!!!!
                              still needs some wiring work.. but all in all.. making decent progress
                              • noisy gears?
