I used to have a 97 silverado and loved it. It too big to fit in the parking garage back when I was at quicken. Plus the trans was on the way out. With all the rust, I decided to cut my losses. Keep your eyes peeled for me. reg cab, short bed, 2wd
Mike's 1986 IROC Z Thread
Well yeah there were the 99 classics and 3/4 tons but those are either not what hes looking for or pretty rare.Originally posted by DynoDave View PostWhat's this?
FYI...There were still GMT400 utes for another year (or two) after 1998. It was a slow, rolling changeover.-Joel
I got ya.Originally posted by JoeliusZ28 View PostWell yeah there were the 99 classics and 3/4 tons but those are either not what hes looking for or pretty rare.
But what's this you are saying about a tuner available for '98 L31s? I have a '98 GMC Suburban with one.DynoDave
At least at the time i had my 98 Z71 the HPTuner suite only supported 98+ pcms. I tuned my own truck with that software. I cleaned up the fuel trims, removed the delay for power enrichment, removed all torque management, and firmed up the line pressure a tad and wow what a difference. That truck went from barely being able to brake torque, to smoke-showing a set of 285 BFG ATs without any help from the brakes. Didnt really add any top end horsepower but the response and downlow grunt of that engine was incredible after i made those tweaks. Really miss that truck...-Joel
So Mike... Which motor?sigpic
Wasn't really looking for a 4x4, but this is a pretty sweet truck for the price. http://www.autotrader.com/cars-for-s...77760005&Log=0Originally posted by JoeliusZ28 View PostWell yeah there were the 99 classics and 3/4 tons but those are either not what hes looking for or pretty rare.
There are some pretty stout third gens on here now, so I'm going to need to keep up. I imagine it would suck to swap an engine just to be the slowest out there.Originally posted by Darren View PostSo Mike... Which motor?
I am 90 percent sold on this motor. http://www.jegs.com/p/Blueprint-Engi...rPage=90&pno=1
Block:
4-bolt main block, 1 piece rear main seal
Passenger side dipstick
Square and parallel decked
Align honed main bearing bore
Cylinders are sonic tested for thickness
Cylinders honed on a computer controlled machine to within .0002'' straightness and roundnessRotating Assembly:
Blueprint premium cast iron crankshaft (1 piece rear main seal)
Chevy heavy beam rods with 150,000 PSI bolts
Hypereutectic pistons; 10.0 to 1 Compression
Hastings Moly rings
Hydraulic flat tappet cam
Melling high volume oil pump
Heavy duty double roller timing setCylinder Heads:
Performance aluminum heads
Hardened retainers and valve springs
2.02'' swirl polished intake valves
1.60'' swirl polished exhaust valvesCamshaft Specs:
Hydraulic Flat Tappet
Duration @ .050'' Lift: 229 Intake / 230 Exhaust
Lift: .480'' Intake / .486'' ExhaustOther Features:
New chrome valve covers
New chrome timing cover
New oil pan
Brass freeze plugs
Horsepower: 375
Torque: 400
I'm going to mate that up to a SPEC Clutch. Stage 1 or 2. With that and my 9 bolt rear with 3.73s, I should be able to pull right with a 5th gen considering the weight of those pigs.
Yes, i'm going to mate that to my T5 for the time being. Next year I'll T56 swap it.
Thanks for that info. The Suburban could always use more low end grunt, especially when towing. Their current list still shows 98-00 Suburbans with 5.7L.Originally posted by JoeliusZ28 View PostAt least at the time i had my 98 Z71 the HPTuner suite only supported 98+ pcms. I tuned my own truck with that software. I cleaned up the fuel trims, removed the delay for power enrichment, removed all torque management, and firmed up the line pressure a tad and wow what a difference. That truck went from barely being able to brake torque, to smoke-showing a set of 285 BFG ATs without any help from the brakes. Didnt really add any top end horsepower but the response and downlow grunt of that engine was incredible after i made those tweaks. Really miss that truck...
That looks pretty sweet. Would love to have that kind of horsepower. You'll never be the slowest 3rd gen on this forum as long as I'm here!Originally posted by ruckusz28 View PostThere are some pretty stout third gens on here now, so I'm going to need to keep up. I imagine it would suck to swap an engine just to be the slowest out there.
Post Whore
- November 8th, 2009
- 3000
- Tyler Porter
- 85 Z28, 91 Trans am
- Clinton Township Michigan
- student
if its 3rd gens and 400s im def part of that club, btw if you do have a 400 i have just about every part for them under warranty =)91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
00 Tahoe Z71........Stock
Enthusiast- July 31st, 2013
- 424
- Taylor H
- 1988 GTA TTop
- Plainfield Township, Michigan
- Meat Processor
Do want! Looks awesome!1988 Trans Am GTA 355 TPI/700r4
Summer/Fall Driver
2001 Nissan Pathfinder V6 4x4 Loaded and Rusty Winter Beater
Always Missed
1999 VW Passat 1.8T/5-speed
1996 VW Jetta VR6/5-speed
1988 Mazda 626 5-speed 300,000 miles
Too small
looks great mike. Got me a motor yet? lolsigpic
