Originally posted by MONGO
View Post
Nate's 1998 Z28 Project
- Greenville, MI
- Die Maker
That will get you to 2 ohm like the OEM setup, but didn't the Monsoon amp filter everything?
Custom grind ftwOriginally posted by nascarnate326 View Postlets play a game called recommend me a camshaft.
I have a 224 224 112 right now, would mind a larger cam since I should have everything else I need.
Torquer V2, yes no?2015 Silverado
Agreed. ^Originally posted by Boost Addict View PostCustom grind ftw
If you really want to go off the shelf something along the lines of this would be a good upgrade.
http://www.tickperformance.com/tick-...1-ls6-engines/
Going to keep the cam and do some other things. Changing cams just isn't worth it at this point since I haven't really unlocked the potential of this 224/224/112. After doing some more research it should be all I need if the correct supporting mods are in place (and they currently are not)
Going to try the whistler mod again tomorrow hopefully.
Who has the best price on tubular A arm and upper control arms? I am looking at the NON lowering version. Go!1998 Chevrolet Camaro Z28 - 6 Speed
- Greenville, MI
- Die Maker
- Greenville, MI
- Die Maker
It sounds like it's searching for a decent idle...or is it just the video?
