Nate's 1998 Z28 Project
  • Originally posted by MONGO View Post
    You should just be able to rewire the connectors. Woofer positive and tweeter positive together, Woofer negative and tweeter negative together. Solder those pairs to their respective speaker pigtails wires. I sent you two of them and am still looking for the other 2. Once I find them, they will be in the mail to you. If you need wiring help, give me a call and I can walk you through it.
    That will get you to 2 ohm like the OEM setup, but didn't the Monsoon amp filter everything?
    • Yes, it has a built in crossover.
      Good point, not sure what you would do then.
      Sent from my VS980 4G using Tapatalk 2
      • Originally posted by sman View Post
        Could you wire the woofers and tweeters seperately?
        • Working on cleaning the wheels up today
          Sucks but theres no way a body shop is going to clean them to the extent I want them clean. Ive got the face of the wheel about 90% perfect, inside of the wheel just got started.
          • Looks good Nate....glad the clay bar worked.
            • lets play a game called recommend me a camshaft.
              I have a 224 224 112 right now, would mind a larger cam since I should have everything else I need.
              Torquer V2, yes no?
                Torquer V2, yes no?
                Custom grind ftw
                2015 Silverado
                • Originally posted by Boost Addict View Post
                  Custom grind ftw
                  Agreed. ^
                  If you really want to go off the shelf something along the lines of this would be a good upgrade.
                  http://www.tickperformance.com/tick-...1-ls6-engines/
                  • I almost want something different, something that doesnt involve me spinning it 6500. I know it might be safe, I just feel better knowing its not screaming up there.
                    I have a EPS custom grind 230/236 I think?
                    • still using 98 heads?
                      • Yes I am using 98 heads. They have some work do the to them.
                        Im more concerned with a sick idle than a dyno number.
                        Will be keeping a safe 6300-6500 reg limiter.
                        Im more of an off the shelf fan. Any other recommendations ?
                        • Going to keep the cam and do some other things. Changing cams just isn't worth it at this point since I haven't really unlocked the potential of this 224/224/112. After doing some more research it should be all I need if the correct supporting mods are in place (and they currently are not)
                          Going to try the whistler mod again tomorrow hopefully.
                          Who has the best price on tubular A arm and upper control arms? I am looking at the NON lowering version. Go!
                          • What's your idle like now? I'm running the exact same cam, assuming it's a TR 224 112LSA. I have the LQ4 and 317 heads though.
                            I want to set the idle a bit lower than what is in the video, I think it's about 900 right now.
                            • Thats the idle now:
                              It looks I can get Spohn upper and lower for 520 ish.
                              • It sounds like it's searching for a decent idle...or is it just the video?
