Originally posted by Nocooler
View Post
Nocooler's 00 Firebird
madman is a hard tube and any of them plain suck to put it, gotta hope it stays in place while you put the trans up in the car, just a PITA. The lokar is nice that its flexible but as you mentioned a pain to fill.Doing less with more
It wouldn't be so bad if this trans was a little lighter - my god took all a could to do get it on the pins.
Now it's gotta come back down and I get to do it all over again
2000 Formula
fixed slow junk
Larry's idea worked flawless.
Dipstick is in
Trans is fully bolted up
Converter is bolted up
Things that are left to do:
Shifter cable install and adjustment
Install cooler lines - waiting on a low profile 90* fitting for the rear of the trans
Install drive shaft
Fill trans with fluid
Upload tune
Do burnouts
2000 Formula
fixed slow junk
Dont know how ive missed this thread. So did you rebuild the 80e? Stock build or something special or upgraded? Havent touched mine yet but got a price of $130 for complete rebuild kit but might upgrade a couple things. Also havent decided on a stall or size of stall. Lmk how you like yours. Track day? Lmk
- - 5.3/4L80e/T7875 - -
- Huron Speed Turbo Kit -
1998 Formula
It's stock internally with a transgo hd2 kit in it. Had under a 100k on it behind a 6.5 diesel in a van. It was nice and clean inside - and I'll find out if it's good here in another week or soOriginally posted by Formula Z View PostDont know how ive missed this thread. So did you rebuild the 80e? Stock build or something special or upgraded? Havent touched mine yet but got a price of $130 for complete rebuild kit but might upgrade a couple things. Also havent decided on a stall or size of stall. Lmk how you like yours. Track day? Lmk
We'll see if I like it - if not the T56 will get face plated and go back in
2000 Formula
fixed slow junk
Made some progress tonight
All that is left is installing the drive shaft - filling it with fluids - uploading the tune.
I hope it doesn't leak and it shifts thru the gears - fingers crossed.2000 Formula
fixed slow junk
