^Lol.
Nocooler's 00 Firebird
Transgo kit is installed - hopefully I did it right
New internal trans harness is in - and the trans is all back together. Damn I need a fork lift to move this thing
My brain has been mush for the past few days. Dr. and I decided it was time to try lowering the dosage of my antidepressants, 1st stage went fine - but this second stage has been rough.
Had to install the a/c unit in the garage - went from hot to almost bearable
2000 Formula
fixed slow junk
Made a plate to cover the hole in floor - and mount the shifter too. Looks like I need some 1" square tubing to raise the shifter up, I have round but no square
Flexplate is mounted - is it me or are the torque converter bolts a ***** to get to?
Put 2 of my -6an fitting on and put my -6an fittings in the trans
Tried figuring out where to mount the trans cooler - damn there is no room. Maybe I shouldn't have bout the big one
2000 Formula
fixed slow junk
You got the starter out right?Originally posted by Nocooler View PostMade a plate to cover the hole in floor - and mount the shifter too. Looks like I need some 1" square tubing to raise the shifter up, I have round but no square
2015 Silverado
