SOB that's where it's at - wouldn't fit anywhere else.
If it doesn't work I'll put a fan on it.
Thats where I got mine at haha. Highest I seen my temp so far was I believe 200? Maybe a tad under...Dont remember exactly..but it was stop/go traffic on highway in Detroit.
Spencer - no way it would fit with the fast toys ram air
Thats the same issue I had. I was planning for a CHRS1313 ram air and nothing will fit on the radiator with that in place.
Mine only got warm sitting in traffic. During the WWDC while I was stuck in Royal Oak my trans pegged the gauge at 250. Started moving and it came right back down. I think the fan will help tho.
Quick question, what do you mean you had yours mounted dope style? I'm throwing the chrs1313 on next weekend when I get home and im scratching where to throw this cooler.
Mine is also dope style. Highest I seen was around 220-240 I believe..but comes down almost instantly once I got out of the Detroit stop and go. Haven't seen it as high since
Mine is mounted laying down in front of air deflector..and just drilled my holes and bolted it in..doesn't move at all..still need to adjust it a bit on the other side but its been holding up going no where.
All "Dope style" means is the cooler is mounted horizontally.
You can actually see where my cooler is bolted directly to my air dam in this picture.
