Nocooler's 00 Firebird
  • #31
    ^Lol.
    2000 Formula
    fixed slow junk
    • #32
      Mine was around 4200. 2-3 shift it would go to the moon lol. 1800 rpm slip at the line. Was fun on the street though
      • #33
        The ridings or the Vig?
        • #34
          I think it was his Vig before he figured out it was sucking the pan dry
          2000 Formula
          fixed slow junk
          • #35
            Ordered a converter this afternoon - I made the mistake of calling PTC.
            10" billet single disc - shooting for 3800-4000 on the engine
            2000 Formula
            fixed slow junk
            • #36
              what a baller, they are def some good guys over there.
              • #37
                Baller? It was almost $200 cheaper than the FTI
                2000 Formula
                fixed slow junk
                • #38
                  Should have everything on the way......just need fluids etc.
                  And some damn motivation to work on the thing.
                  2000 Formula
                  fixed slow junk
                  • #39
                    Transgo kit is installed - hopefully I did it right
                    New internal trans harness is in - and the trans is all back together. Damn I need a fork lift to move this thing
                    My brain has been mush for the past few days. Dr. and I decided it was time to try lowering the dosage of my antidepressants, 1st stage went fine - but this second stage has been rough.
                    Had to install the a/c unit in the garage - went from hot to almost bearable
                    2000 Formula
                    fixed slow junk
                    • #40
                      T56 is out.
                      2000 Formula
                      fixed slow junk
                      • #41
                        Made a plate to cover the hole in floor - and mount the shifter too. Looks like I need some 1" square tubing to raise the shifter up, I have round but no square
                        Flexplate is mounted - is it me or are the torque converter bolts a ***** to get to?
                        Put 2 of my -6an fitting on and put my -6an fittings in the trans
                        Tried figuring out where to mount the trans cooler - damn there is no room. Maybe I shouldn't have bout the big one
                        2000 Formula
                        fixed slow junk
                        • #42
                          You got the starter out right?
                          2015 Silverado
                          • #43
                            Is that the trick? I'm not ready to install the trans.....but I was looking at it after I installed the flexplate.
                            Thanks Ricky
                            2000 Formula
                            fixed slow junk
                            • #44
                              did you get extention fittings for the trans?
                              • #45
                                I just swapped mine to an M6, I could of gave you the center tunnel metal I cut out of mine
                                2002 Z28 Camaro A4
