Gaspo's 99 trans am project
  • Originally posted by 1999Black_Z28 View Post
    Thank you for supporting my turbo build! I had that money for less than 12 hours before handing it over to Jonny for a TC78
    Which cam did you end up going with on this build?
    i know how that goes. stephen, who bought my camaro is picking up a huron speed kit today. here are the specs on the cam thunder racing "trak" cam 640/590L 234/231D 111lsa
    • Nice!!! I bet that thing sounds mean
        sounds pretty good. havent got the trunion upgrade kit yet... bad alternator i think so i didnt drive it much last night
        • Just met with Stephen and got him his kit, small world!
          • Originally posted by Superman09 View Post
            I told him about your kit
            • I'm getting the u1301 code. And my system isn't charging fully. Any common issues with these cars?
              • Fixed it. The wire ripped out of the plug on the alternator. Good to go now I have a loose ground somewhere
                • fixed!!
                  • fixed bad ground wire too!!
                    • good to hear that its coming together nicely
                      • Originally posted by Formula Z View Post
                        Thanks Mike. Was just told the car is speed density tuned. I'm wondering if that's why it stalls at idle now? The intake is different then what was on it. Not sure if the map sensor was different. I had to get a 2 bar map sensor for my sd tune last time. Any ideas?
                        • What intake was on it? and what did you put on it?
                          S/D tuning is pretty sensitive to changes.
                          I'd get it retuned - so you know it's right. Without boost the stock map will be fine.
                          2000 Formula
                          fixed slow junk
                          • Originally posted by Nocooler View Post
                            It had an ls6 intake and ported tb. I put on Livernois stage 2 heads, and stock intake
                            • Originally posted by Gaspo View Post
                              It'll need retuned - that's a pretty big change.
                              2000 Formula
                              fixed slow junk
                                I want to get an ls6 intake soon. Should I get that before tune? It runs and drives good besides when I let off the gas. Sometimes it idles great and sometimes it wants to die.
