Ahhh, well when it comes in ill have to check it out and see if its for all four. i called betten chevy and berger chevy, berger chevy is the 1 that said pre 02 has plugs in the back.
kinda confusing
Gaspo's 99 trans am project
Lurker- August 27th, 2008
- 452
- Anthony Z
- 1989 Trans Am GTa V8
- Muskegon, MI
- mechanic/quick lube tech
the P/N you got was correct the 99 and later block off the rear ports as these guys mentioned. If you choose to use a 98 style 4 port crossover you will have to use an LS1 intake manifold or grind/chisel off the ribs on the bottom of an LS6 for it to fit properly. There are other options as well depending on how fancy you want to get I'm waiting for Larry to make me one with some brake line
I would use all 4 personally. Coolant and steam just roars out of their when the engine is running. If using a LS6 intake just chisel the ribs off. I had less than 2 minutes into mine. Used a 1in chisel and a small hammer, one quick pop and the ribs fly off, literally, just where safety glasses or something.1999 Camaro - 6 liters of fury.....
i have an ls1 intake. i dont get why they would block the two off, if they are needed.98 z28, m6, monster clutch, eibach pro kit, custom twin turbo setup, 317 heads, z06 valve springs, arp rod bolts, 512rwhp at 10lbs. cobra eater
Maybe that came out wrong. I want the 4 port one. I don't get why it would be blocked offOriginally posted by DETROITMUSCLE View Postfeel free to read up on it, I have done my fair share and have decided to run all 4 ports on my car you do it how you see fit.98 z28, m6, monster clutch, eibach pro kit, custom twin turbo setup, 317 heads, z06 valve springs, arp rod bolts, 512rwhp at 10lbs. cobra eater
The 4 port setups (LS1) have been superseded via the 2 port setups (LS6).
I doubt you'll find a new one - if you need a 4 port setup you'll need to find one used, buy an aftermarket one (Kurt Urban) or put one together yourself.2000 Formula
fixed slow junk
Grammar Nazi
- January 10th, 2006
- 6647
- Jonny
- under par
- Huron Speed
I believe I may still have my 4 port coolant crossover in the garagesigpic
i'm using the ls6 style for now.. going to keep looking for a 98 one. i have everything ready to go.. just waiting on intake bolts now. also need the bracket where the throttle and cruis cables connect to the intake if anyone has them???Last edited by Gaspo; April 17th, 2012, 11:28 PM.98 z28, m6, monster clutch, eibach pro kit, custom twin turbo setup, 317 heads, z06 valve springs, arp rod bolts, 512rwhp at 10lbs. cobra eater
