Gaspo's 99 trans am project
  • Originally posted by 1999Black_Z28 View Post
    ^^^What Mike said...
    I would have kept those heads and went with E85 if I didn't need the extra money to fund the turbo
    The plan right now with my build is to get it on the road with low boost, stock 10:1 compression and 93 oct. When I can afford to build the fuel system it will get 15+PSI, stock 10:1 compression, and E85.
    Compression makes power period you just need the right fuel to use it.
    • So keep the heads? I'd really like to stay with 93 octane.. I have other heads I can put on this engine to sell it complete
      • I wouldn't run those heads with 93. If your other heads are lower compression use them and sell the 243's. If not sell everything and buy stock 317's. 317 heads and valve job cost me less than $300
        • Originally posted by Gaspo View Post
          what's the cheapest way to go? i'll drop the motor, replace the head gaskets and bolts (heads are almost off). i'll take the oil pan off and clean everything out as best as i can. how do i test the springs? tje retainer on the spring with the bad rocker is chipped/dented a bit. can i just buy one replacement retainer?
          I just have stock 98 heads..
          • the 98 heads are scrap buy some 317s like mentioned that will help lower your comp ratio a bit due to the larger chambers.
              And the 317's flow better than stock so it's a win-win
              • I can't remeber the exact specs off the top of my head but for reference the C/R's are something like this (assuming stock LS1 block/pistons/etc):
                Stock LS1 heads= 10.2:1
                LS6 (243's)= 10.7:1
                Truck (317's)= 9.5:1
                • Lowering the compression will allow you to run the boost up on 93 octane.
                  • What year 6.0 should I look for and stay away from? And just port the stock 317's then?
                    • most people (myself included) just leave the 317's un-ported. For my own piece of mind I had a VJ done but most guys dont even do that, they just swap springs and run 'em.
                      • 04+ has stronger rods I believe. But anything that comes stock with an aluminum head is usually a good choice.
                        • I did ls6 valve springs in my last 317's. Good way to go? Keep stock rockers? I have an ls6 cam. I heard those are good for boost
                          • if your running a stock cam I'd get the LS9 springs, cheap and should work better than the LS6. If your going aftermarket cam might as well go with some doubles.
                            • Just stay away from the Iron headed lq4's. They have a different flexplate and some weird adapter because the crank is shorter.
                              Also, I would advise staying away from the lq9's. Those are higher compression, 10.something IIRC.
                              And im PRETTY sure only the lq9s got the new style rods in 03/04. So it SHOULDN'T matter. But I could be wrong here. Worth some research for sure...
                              • This may help....
                                6000 Vortec 6.0L
                                LQ4
                                The Vortec 6000, or LQ4, is a V8 truck engine. It is a bored version of the Vortec 5300. Displacement is 6.0 L (≈366 cu in) from 101.6 mm bore and 92 mm stroke. It is an iron/aluminum (2000 model year engines had cast iron heads) design and produces 300 horsepower (220 kW) to 325 horsepower (242 kW) and 360 lb·ft (488 N·m) to 370 lb·ft (502 N·m). LQ4s are built in Romulus, Michigan and Silao, Mexico.
                                LQ4 applications:
                                Chevrolet Express/GMC Savana
                                Chevrolet Silverado 2500 Pickup, 3500 Pickup, Crew Cab, and Chassis Cab/GMC Sierra 2500 HD Pickup and Crew Cab, C3, Denali, and 3500 Pickup and Chassis Cab, 1500HD Crew Cab
                                Chevrolet Suburban/GMC Yukon XL Denali
                                Hummer H2 SUT
                                GMC Yukon Denali
                                LQ9
                                The Vortec HO 6000 or VortecMAX is a special high-output version of the Vortec 6000 V8 truck engine originally designed for Cadillac. This engine was introduced in other truck lines as VortecMAX for 2006. It features high-compression (10:1) flat-top pistons for an extra 10 hp (7.5 kW) and 10 ft·lbf (14 N·m), bringing output to 345 hp (257 kW) and 380 ft·lb (515 N·m). LQ9s are built only in Romulus, Michigan. GM also listed it as based on LS architecture.[1]
                                LQ9 Applications:
                                2002-2006 Cadillac Escalade
                                2002-2006 Cadillac Escalade EXT
                                2003-2006 Cadillac Escalade ESV
                                2003-2007 Chevrolet Silverado SS
                                2004-2005 Chevrolet Silverado and GMC Sierra Vortec HO Edition Only [Badging on truck]
                                2006-2007 Chevrolet Silverado and GMC Sierra VortecMAX Option
                                The 99-00 6.0L had the longer rear main flange on the crank. It was 1.25 inches thick. They also came with Iron Heads. in 01- up the swithched to the standard more common crank flange thickness which measures .857 at the rear main flange area. They used a spacer between the crank flange and fly wheel to compensate for the extra thickness need to get the fly wheel to bolt up with the 4L80E Torque converter. As a result the Bolts are also longer... 01 6.0L was also the first year for the Aluminum Heads on the 6.0L
                                The camshaft is the same in the LQ4 and LQ9. It has same part number on it.... The diffrence is the pistons and rods... The LQ4 which is pretty standard for the truck line up has a slight dish in it while the LQ9 has a flat top piston... The LQ9 is ussually found in the High end caddy SUV, SS Truck, and the VHO optioned crew cabs
                                Now in the first designLQ9 piston I believe they used a standard LS1 rod with a pressed pin. They Later (04 LQ9) switched to the beffier LS2 rod with a Floating pin flat top piston.
                                Yes the LQ9 piston Is the same flat top piston used in the LS2. They have a floating Pin. The conecting rods are also the same.
                                The difference In power comes from the added compression and the factory programing. The LQ9 is tuned for more performance with the bump in compression.
                                Factory camshaft part numbers
                                The 99-00 LQ4 6.0L used the 12560967 - this is also used in the 5.3L
                                The 01-up LQ4 6.0L used the 12561721
                                The 02-up LQ9 6.0L also used the 12561721
                                Factory Camshaft specs are:
                                12560967 191/190 duration at .050 0.457/0.466 lift on a 114 Lobe center
                                12561721 196/207 duration at .050 0.467/0.479 lift on a 116 Lobe center
