Gaspo's 99 trans am project
    I would do dual pumps right from the get go. A single isn't going to take you much past 10 PSI safely. It only takes 1 instance where the pump gets hot and drops a few PSI to melt down that turbo motor.
    makes sense. Are stock lines and fpr and rails ok?
    • What are your power goals?
      • Originally posted by 1999Black_Z28 View Post
        Mid 600s?
        • Originally posted by Gaspo View Post
          Mid 600s?
          to the tire ?
          i agree with those guys.. 60# injectors will be plenty for that combo.. i also would advise upgrading the fuel lines if you want to do those numbers safely.. i would do at least -8 feed and -6 return. you will also want to go with aftermarket rails and fuel pressure regulator as it is much much safer too. one drop in a safe amount of fuel and its toast. kind of like the fuel pump situation.
          • Originally posted by kammi10 View Post
            to the tire ?
            What he said ^
            I would upgrade the fuel lines, rails, and regulator for that kind of power. Guys have made it with stock stuff but guys have also burned there shit up trying.
            I'm running dual 255 and stock lines with mine but I don't plan on turning it up much past 525-550 until its all upgraded.
              What he said ^
              i agree.. i wouldnt go much past that point if you arnt going to upgrade everything else.. plus you have a 6 spd so its going to show better numbers than mike will with his auto..
              • sounds like i have a good shopping list to start towards!
                • I'd add an NGK AFX wideband to the list - and HP tuners.
                  With turbo cars your always playing with them - might as well have the proper tools to tune it.
                  2000 Formula
                  fixed slow junk
                  • Originally posted by Nocooler View Post
                    i've got a lmc-1 wideband in it right now. hp tuners is a good idea. when i sell my engine, do i sell the wire harness and computer with it? or keep them? will they work for a 5.3?
                      Keep it....
                      2000 Formula
                      fixed slow junk
                        Keep it....
                        ok sweet!
                        • does anyone have an opinion on what price i should list my engine as?
                          livernois stage 2 heads, around 6k miles on them.
                          patriot dual gold extreme valve springs
                          new valve seats/seals, titanium retainers
                          comp hardened pushrods
                          LS2 timing chain, ls1 ported oil pump
                          volant cold air system
                          thunder
                          racing "trak" cam 640/590L 234/231D 111lsa
                          oil pressure is ata 35 when hot at idle, 60-65 when engine is cool at idle. 40psi when cruising down the highway. 10w30 mobil 1 full synthetic oil used short block has 125k, believed to be origional.
                          • no opinions?
                            • i havent updated this thread in a while. i didnt drive the car for a couple months when i had the bike. it rained like twice so i rode the bike all over. i'm taking the car to martin tonight to see what it'll run.
                              • good luck!
