I assume you have to take off the pulley each time you change the seal. Did you put in a new bolt each time as well?
well after allan just pm's me i found out the bolt are torque to yeild. So i dropped the ball on that one and falled to relize they where. i just orderd new ones for the other engine's iv done becouse of the leval of the builds so looks like we have it. thanks guys. im going out to allans house on thursday or friday to fix the problem.
Crankshaft Balancer Bolt (Installation Pass-to Ensure the Balancer is Completely Installed) 240 lb ft
Crankshaft Balancer Bolt (First Pass-Install a NEW Bolt After the Installation Pass and Tighten as Described in the First and Final Passes) 37 lb ft Crankshaft Balancer Bolt (Final Pass) 140 degrees
thanks alot. good to know. i'll be back in a few i have to go kick my ass.
Not that big of a mistake - it'll be just fine with a new bolt. Just so you know... achieving the actual torque spec is next to impossible. We had 2 guys with a breaker bar on it trying to hit 140* and I think we may have only gotten to ~110* (pretty typical from what I've read)
thankyou for your information. i torqued the old one down but you know how that went.. big torque wrench and we will see what happens.
Well Ken came out to my place today and took care of the situation. New balancer, seal, bolt, & belt. Everything seems to be just fine, we did a test drive, the car feels a lot better and there doesn't seem to be an oil leak at all.
Huge props to Ken for manning up to the situation, it was an honest mistake that he took care of for me on his time.
he still is human, but also one hell of a guy! new vids
Unfortunately no vids, but I did get to Milan yesterday. The car ran a 12.3 @ 110 with a 1.9 60 foot so it's just not hooking up. We found out that the tires are pretty old and the people with me said I need to do a hell of a longer burnout as well. Live and learn, but I had a really good time and the car is running great otherwise. I ended up winning first round of eliminations at the HS nationals, but went too fast on the second round.
well slick have a used life of about 2 years years some will not agree. a longer burn-out on a older slick can help. either way the way i do my burn-outs is start out in secound gear run the rpms up to about 4-5k rpms then shift to secound, hold your rpms in secound to around 3-3500 rpms till you feel the tires start to push you. I hope you had alot of fun
did you have to pedal the car at all or anything? That mph seems a bit down on power to me, I'm certain that car wants more gear and converter.
I pedaled it off the line because it was spinning but that's it. I don't disagree with you on the gear and converter idea though, just a matter of time before it gets done.
i know the he has talked with me a couple times and its deffenatly on his list of stuff to be done.
