Originally posted by c0ncEpT
View Post
Sleepers project thread By SniperPerformance
Keep an eye out on ls1tech for a used fast 78......if your quick you can snag one for $100 more than an ls6 intake. It'll help it breathe a little more than the LS6. It's worth 2-3mph on a bolton car over the LS1 - it could be more on your cammed car. Either intake will require a retune - fwiw.Originally posted by Sleeper View PostI never knew!2000 Formula
fixed slow junk
That's interesting how it has the fins like an LT1 intake.- Brian Meissen
yeah you will definitely want to go see a tuner to make a few adjustmentsOriginally posted by c0ncEpT View PostI don't see a fast 102 in that picture
Should rip tho. Probably need to make a trip to the tuner for some adjustments. I'm sure even that BBK is pulling a shat load more air than the LS1 intake was.
Just to echo what the guys above are saying.....
when I installed my fast 78 - my car went from running 12.8:1 to 15:1 @ WOT - I didn't even get to 5000rpm before it lean out and I lifted.
I retuned the VE and MAF tables - as it was such a drastic change.2000 Formula
fixed slow junk
That intake looks sweet. I'm curious how much that will improve your times.sigpic
that's awfully impressive for an intake swap! I dig it!Originally posted by Sleeper View PostOh you know I got that shit tuned. Gained 17 wheel, not too bad.
http://www.racecarlistings.com/camaro/dyno2.jpg1998 Camaro SS Bullseye Turbo
