yea so whats next ?
Sleepers project thread By SniperPerformance
well maybe I can give you something to take to Ken for me if you beat me up to his place, when are you planning on going ?Originally posted by Sleeper View PostUpgrade the fuel system, fix some of the minor issues still in it that we found after the little tuning that's been done, and there should be an LS6 intake waiting there for me too
As soon as he's ready. I gotta get in touch with him though, last time we talked he was still doing a cam swap for someone.Originally posted by Gregs_gsxr View Postwell maybe I can give you something to take to Ken for me if you beat me up to his place, when are you planning on going ?
on a red trans am maybe ?Originally posted by Sleeper View PostAs soon as he's ready. I gotta get in touch with him though, last time we talked he was still doing a cam swap for someone.'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
Yep, a LE cam and some Trick Flow heads.Originally posted by Gregs_gsxr View Poston a red trans am maybe ?sigpic
That thing sounded and looked off the chain! you have a nice car sir!Originally posted by ryanwarby01 View PostYep, a LE cam and some Trick Flow heads.'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
Originally posted by kammi10 View Postthat sounds good
sure does, now we need some clips of a drive by and a lanch'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
Well she's back home again! Ken pulls through again big time. Fuel system, LS6 intake, ARP wheel studs, rear end sealed up, engine sealed up, fresh 02 sensor.
Going to the Dr next week for a final dyno tune before I hopefully hit Milan before the season ends.
well allan called me today and said he is still having a problem that has me stumped. the only thing i can think of is windage or even a bad balancer. so give me some ideas how to help him out i have never had this issue out of a ls1 and iv done about 7 of them.
ok heres the problem. for some reason even after a 2 new front harmonic seals this engine is leaking engine oil, and it gets progressively worse the higher the rpm's ( sounds like windage). how ever they are for some reason feeling vibrations also. this engine still has factory balancer and, i know they are prone to going bad but the car has alittle over 100k on it. i can't see it going bad already. even though its is possible. allan said it was wharing the assesory drive belt kinda funny. iv also heard of needing to up-date the harmonic bolt but never have on such a mild engine. dose anyone have any idea's? allans a good guy and i gotta get this thing right for him....
