Smans 6.0 build up!
  • #61
    Originally posted by shawnc16 View Post
    Thats gonna be 11 to 1 compression with 243s. I wouldn't take it out and beat on it at all until you get it tuned.
    never a good idea regardless
    • #62
      He has the best tuner in the area. No worries
      • #63
        Yea had a chat with Phil, he said it should start and run decent, but that sounded like that was about it.
        Going to pickup some gaskets, bolts, etc on lunch today, get the heads after work, and should have my iron ls2 put together by 9 tonight
        • #64
          great news Spencer its nice to see you get bit by the hp bug
          • #65
            Awesome spencer! And don't worry about hitting 11s, you will
            • #66
              Originally posted by Plum Nuts View Post
              Well don't overlook the basics, if you put more compression on top then you really need to rebuild the bottom end. The bearings have to take all the new hp stress. If you mill or change heads you are starting down that slipry slop, you should redue the bearings aswell. Just my opinion.
              you must not have seen the pictures of the engine he is putting in.. its almost as clean as new and has hardly any miles.. he doesnt need bearings nor will he for a long time.
              • #67
                I raised my compression from 10.5:1 to 11.4:1 on a 90k mile engine and its been fine.
                • #68
                  You better knock on the Chris Craft in your avatar!!
                  • #69
                    • #70
                      Looks nice sman. Maybe I missed it but are you sticking with the 224 or are you going bigger
                      2000 Formula
                      fixed slow junk
                      • #71
                        224, because I already have it, not getting the heads tonight.... Supposed to be able to get them tomorrow, fingers crossed!
                        • #72
                          nice man
                          update?
                          • #73
                            Picked up a set of 799's tonight! Thanks Steve @ SBTuning!
                            Have my final in my unix class tonight, has to be submitted by midnight, so the car is getting put off by a day, motor goes together tomorrow!
                            • #74
                              Sweet! Should be a sweet set up!
                              • #75
                                Got all the springs off of my 862 heads ready to go on the 799s. Waiting on head gaskets and valve seals, ran out of time and couldnt get any after work. Picking them up tomorrow morning.
                                Soooo, painted the block, only picture I have, this is the passenger side, before it was all done. Used the nasty front cover off the 5.3 to protect the front of the motor, dont worry not painting the clean one that came off of the 6.0.
                                Came up to the house to take a break, heading back out to polish my fuel rails, wish me luck!
