Originally posted by sman
View Post
Smans 6.0 build up!
Lurker
- March 13th, 2010
- 3476
- TJ
- 1995 Chevy Camaro Z28
- Clinton Twp Michigan
- Powerline Tree Trimmer.
Are you going look into a port job or even a home port job?Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Yeah I'm with Shawn on this esp. since your using the TR224. If you were going with more Cam then maybe the extra compression would be more worth it.Originally posted by shawnc16 View PostLike I said earlier, a half point of compression is only good for about 10 hp aand10 ft lbs. Not worth it IMO but, its yur build. Its just money.CraigSemi Retired Street Racer2012 Lava Red Mustang GT 5.0 MT82GONE BUT NOT FORGOTEN
NBM `98 Formula M6 HdTp
1 of 1 Build Date 3/12/98
- Smokey Yunick
Dont get caught up on dyno #'s. There was a member here who's car only made 360 threw an auto that went mid 11's.Originally posted by sman View PostFair enough, thanks for the info. If I can get the 243s cheap ill go with those, if not ill run the 317s.
I was looking for the 400mark, but ill be thrilled if I can get a 11.99pass.
So what valves can you buy, aftermarket, that are about the same or better than the real LS6 valves?Originally posted by 1BADAIR View PostLS6: intake = 73 grams, exhaust = 65 grams
LS1: intake = 101 grams, exhaust = 94 grams.
Can't wait to see what I can do (after I get a new rear).Originally posted by c0ncEpT View PostDont get caught up on dyno #'s. There was a member here who's car only made 360 threw an auto that went mid 11's.
Spencer I don't think you'll be disappointed after stepping up .7L with rings that actually seal.
Used to own a Firebird.
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
Well don't overlook the basics, if you put more compression on top then you really need to rebuild the bottom end. The bearings have to take all the new hp stress. If you mill or change heads you are starting down that slipry slop, you should redue the bearings aswell. Just my opinion.sigpic
Got the engine and trans separated yesterday, along with all the accessories off of the 5.3 and the 5.3 out of the kmember on to its temporary home where all the rest of the parts(cam, pan, pickup tube, etc) will be harvested.
No progress today, had a massive headache, I could have sworn someone beat me in the head repeatedly with a baseball bat without my knowledge.
Flip side is I contacted one of our sponsors and will be picking up a set of 243s tomorrow for a very reasonable price! Going to have the heads checked, get valves and springs put in and we will officially have all the parts for the 6liter!1999 Camaro - 6 liters of fury.....
