what all is the builder doing to the motor?
InActive Member
- November 19th, 2006
- 527
- dustin
- 1989 camaro rs, 2002 gmc sierra 1500,1999 chevy tahoe 2dr lifted
- rothbury michigan
- automotive technition
228/230 .587 112lsa comp cam. builder honed the block, machined the crank, installing some forged mahle pistons and rings. new rod, cam, and main bearings. arp hardware throughout (rods, mains, head). milling my stock ls1 heads and installing new seals and comp cam 918 springs and valve job. balancing rotating assembly or at least checking it. i could save myself 300 bucks going back to stock pistons but then i believe the new pistons will be .10 over and i dont think i can bore it that far out. already .05 out with the mahle pistons. plus if down the road i want to add some spray, im set, right?Last edited by Formula Z; January 19th, 2011, 08:41 PM.sigpic
- - 5.3/4L80e/T7875 - -
- Huron Speed Turbo Kit -
1998 Formula
what kind of numbers should i be putting down now without the ls6 heads? if i mill the 806 ls1 heads with the 228/230 .587 112 comp cam and 3200 stall. i dont want to go longer without my car but wonder if i should just hold off and get some different ls6 heads. can i still reach 400rwhp with what i got?? thankssigpic
1998 Formula
I don't think you'll hit 400 with that small of a cam and those heads, I'd say 370ish would be about right with the converter locked.Doing less with more
really i thought this was a bit bigger then what i needed lol. damn what else can i do to get the 400whp without doing the heads? heads are going to have to wait for a bit. roller rockers, ported tb, underdrive pulley???? what was i thinking selling them ls6 heads?!?!?!Originally posted by DETROITMUSCLE View PostI don't think you'll hit 400 with that small of a cam and those heads, I'd say 370ish would be about right with the converter locked.sigpic
1998 Formula
http://www.ls1tech.com/forums/parts-...0-shipped.htmlOriginally posted by Formula Z View Postreally i thought this was a bit bigger then what i needed lol. damn what else can i do to get the 400whp without doing the heads? heads are going to have to wait for a bit. roller rockers, ported tb, underdrive pulley???? what was i thinking selling them ls6 heads?!?!?!sigpic
