  • timing chain is off so the only thing moving is the crank and pistons and something is causing it to be grabby and stuck
    - - 5.3/4L80e/T7875 - -
    - Huron Speed Turbo Kit -
    1998 Formula
    • Originally posted by Formula Z View Post
      Did you replace your main and rod bearings?
      • nope
        1998 Formula
          nope
          Didn't you pull a cap to look at a bearing? If not, than very wierd cause you didn't do anything to the bottom end. If so, are you sure the bearing seated correctly when you put the cap back on?
          • i'm with jeff. first there is some junk(loctite) or something right behind the dot
            then it look like there is something else between the block and gear
            • yeah there was some locktite, but behind the gear is only the crank itself. like i said its never been out so it has to be right, at least that part. started disconnecting the wiring harness again, actually done, and will drop it out again and start over. it has to be the crank and/or bearings. like larry said i did pull the first main cap and first rod cap to check the bearings. they were good so i put them back on which i know is a no no, but i did and may have screwed myself.
              1998 Formula
              • can you take another pic of that spot we are talking about. never seen that before
                • ill try and get another tomorrow. i think i figured it out though. seems like i put the rod cap on backwards and its rubbing the counterweight(?) of the crank. simple fix should consist of flipping engine upside down and reversing the cap, if i didnt damage the bearing. ill be dropping the motor friday night for those of you who would like to join me, lol
                  1998 Formula
                  • nobody wants to learn ls1? haha its cool, i can almost do it all by myself now. beer and bbq for me
                    1998 Formula
                    • Man, I would but I leave to go home Friday at 5pm and start class again on Monday. Got stuff to take care of man.
                      Used to own a Firebird.
                      • its cool vinnie, but i wont let those excuses work all summer. you will have to come down and cruise grand rapids with me
                        1998 Formula
                        • I'm leaving Friday to go home to White Lake, which is on the east side...two and a half hours away. I'll probably be back up some time this summer though.
                          • well it seems that you cant just pull the first main cap and re-torque. my problem was that the crank must have sprung causing a bind once i re-torqued it down. once i loosened the rest of the caps, the crank rolled over like it should. so looks like im going to be needing at least new main bearings but i might as well do the rod bearings too, and why not new piston rings. i dont think my car will be out this year
                            1998 Formula
                              As much as it sucks, I think it's the right decision based on what I saw when we pulled the caps..
                              • you think oe bearings will work? seems like i can get those cheapest right now unless someone knows where else i can get them
                                1998 Formula
