^ I also like the bushing. Also that throw out bearing should be just fine. Plus, they're around $70 to replace IIRC.
aka Purple94Z28
- May 1st, 2009
- 1858
- Nick Kerns
- 1999 BBM z28 Camaro
- Saginaw Michigan
- New Car Sales Consultant
Let me know if you decide to do the swap another time besides next weekend and ill be down to help!!
Edit: swapping the plate from the white car to the purple one so i can drive it until it sells so i can come down with the pmp twin!!1999 z28 Bright Blue Metallic 1 of 10
aka Purple94Z28
- May 1st, 2009
- 1858
- Nick Kerns
- Saginaw Michigan
sorry for the hijack but i'm also looking for a new pilot bearing or bushing and i cant find a bushing on summit that says it fits the LT1.1999 z28 Bright Blue Metallic 1 of 10
@hoogiesngrinderz would I be able to drive with my stock a4 tune? At least to get it home?Last edited by mcalus; July 13th, 2013, 03:24 PM.2002 Z28 Camaro A4
- Greenville, MI
- Die Maker
Yup, it will run. I'm not sure if LT1 computers have park/neutral and in gear tables like LS1 (manual LS1's have P/N and IG tables, but the P/N tables are for "clutch in" engine control)
I'll look at the LT1 bins tomorrow after work.
Awesome thanks! I just don't want to ruin something :/Originally posted by hoogiesngrinderz View PostYup, it will run. I'm not sure if LT1 computers have park/neutral and in gear tables like LS1 (manual LS1's have P/N and IG tables, but the P/N tables are for "clutch in" engine control)
Tomorrow ill start tearing into the interior. Removing the things I can.
I think one of the hardest things to remove will be the steering shaft.2002 Z28 Camaro A4
Getting things ready as possible for the swap this weekend.
I need to get a U-bolt for the clutch master cylinder to bolt to the firewall. Suggestions? Dealer said there isn't one at a dealer in the world... My luck. Could I use a standard exhaust u bolt? Or does anyone know a replacement or the size of the stocker or even a pic?
This is about as far as I can get with keeping it drivable (to take to buddy's garage to use his hoist)
Anyone have some torque specs ill need?
Flywheel
Pressure plate
Where can I get the pilot bushing? My buddy works at carquest and said he can get the bearing for $28 but said that's all that was showing up.2002 Z28 Camaro A4
Ordered a pilot bushing through rockauto. $18 shipped (hope I get it by Saturday)
Anyone have a cheap shift knob laying around I could buy or borrow until I order the C6 knob?
Hopefully ill get the dustshield from Patrick before this weekend is over.
Also need to swing out to Joel and get the upper center console.
Still need to figure out a u bolt for the master.2002 Z28 Camaro A4
- Greenville, MI
- Die Maker
Why couldn't you use two bolts for the master? That's what I did for my third gen swap...am I missing something with the 4th gen?
- August 16th, 2007
- 2881
- Jim
- Traverse City, MI
Im willing to meet you part way on the upper console piece, but I am out of town until Monday!Originally posted by mcalus View PostOrdered a pilot bushing through rockauto. $18 shipped (hope I get it by Saturday)
Still need to figure out a u bolt for the master.-Joel
